J3 Cub with C-85 Exhaust modification
I was helping out a friend over the weekend, who was trying to install a B&C alternator on his J3 Cub with a C-85 and it looks like the exhaust needs to be modified to allow room for the alternator, as it's a pretty tight fit at the back of the motor.
My question is, has anyone come across this issue and if so, is there a modification or an stc'd exhaust system to accommodate? Anybody up in Alaska find a cure to this problem? Any advice or suggestions would be much appreciated.
canuck180 offline
22
- Aircraft: Cessna 180
Is that the standard drive location for an alternator on the C-85? Or is it the little B&C acc drive model?
2855
It's the little B&C drive model which fits into the opening on the lower left side of the engine. From what my friend was told from Aircraft Spruce when he ordered, it was suppose to bolt in without issue. It does bolt in, however the exhaust heat shroud comes right up against the alternator and there's not enough room get the exhaust back on without having to make some kind of modification. I was wondering if anyone else has come across this? Thanks...
canuck180 offline
22
canuck180 wrote:It's the little B&C drive model which fits into the opening on the lower left side of the engine. From what my friend was told from Aircraft Spruce when he ordered, it was suppose to bolt in without issue. It does bolt in, however the exhaust heat shroud comes right up against the alternator and there's not enough room get the exhaust back on without having to make some kind of modification. I was wondering if anyone else has come across this? Thanks...
Did you ever solve this?
AEROPOD offline
479
I'd maybe call the folks at Univair, or Atlee Dodge and see if they can help. I assume this is a C-85-12 ??
10514
