Javelin tanks
Fri May 20, 2011 11:00 am
What would a used Javelin fuel tank for a 170 be worth?
Can you even get new ones?
I know some don't like having fuel inside the cabin, but it sure beats 5 gallon jugs plus it vents to the outside!
AKclimber offline
214
Fri May 20, 2011 12:18 pm
del-air has an STC for 48 or 60 gal. in the wings were it belongs a much better option in my opinion.
River rat offline
750
Fri May 20, 2011 12:40 pm
ccurrie wrote:del-air has an STC for 48 or 60 gal. in the wings were it belongs a much better option in my opinion.
Yes, but how much $$$?
AKclimber offline
214
Fri May 20, 2011 12:50 pm
I mostly agree with ccurrie.
Nothing changes with any of the plumbing with the Delair tanks and are gravity fed.
No need to wire in an electrical pump. No need to remember to pump it up.
The Delair tanks also work if you loose lectricity. Have not run out of gravity yet.
Too many accidents end up on their backs or bent in the middle.
I have the LONG rang tanks from Delair.
Only minor argument with ccurrie is that the totals are 52 and 67.
Harry's EXTENDED range tanks add onto the end of the existing tank and go out one more rib.
That make 7-1/2 gals. per side. Matches up with the C175 wings.
The LONG range tanks go out two ribs per side. or a total of 30 gallons extra.
As before I advise the EXTENDED range tanks.
The LONG range tanks are a bit more of an installation challenge.
Chris C
wannabe offline
782
53 C-170-B+
Chris,
What was the cost of the DelAire tanks?
AKclimber offline
214
Sorry I was thinking in Canadian gallons. As I recall Harry quoted me 6000 for the 67gal. I believe that was plus install. It was a couple years ago so I cant be sure. give him a call he is a wealth of cessna knowledge
River rat offline
750
AKclimber wrote:What would a used Javelin fuel tank for a 170 be worth?
Javelin Tanks were optional equipment from factory -carry about 18 gallons and can be added to airplane with log book entry. I know where I can get several tanks . Plumbing goes up to r/h wing main and pumps up with pump. I've had several . Jeff Fields has his removable (54 C180) or useable for long trips. I've also got a set of "Flint Tip Tanks -24 gallon " that I'd part with for the right offer. Javelin Tanks sometimes found on ebay will go anywhere from 100-600 bucks. My bladder-ears won't last over 5 hours in my old 182,with extra fuel it goes another 2 hours so you could out and back sometimes .
182 STOL driver offline
1529
I had a Javelin tank in my 170B. It worked real well and that extra 18 gallons really extended my range without a major retrofit with wing tanks. We also put an aux tank in my wife's 150/150. Kind of grossed her out with that big O-320, but once again it was a good solution for a small airplane.
Nizina offline
499
Nizina
