As of this morning.
LANDMARK COMPLEX
Fire Information Update
Fire Information Number (208) 384-3266
Valley County Sheriff’s Department (208) 382-7150
August 13, 2007 8:00 p.m.
GOVERNOR SIGNS ORDER FOR YELLOW PINE AND JOHNSON CREEK RESIDENTS TO EVACUATE 8:00 A.M., AUGUST 14
COX RANCH, Idaho…Due to extreme fire danger and the probability of fire impacting the Johnson Creek, Yellow Pine area, Valley County Sheriff, Patti Bolen, has requested and received a signed order from Governor C.L. Otter for a mandatory evacuation of Yellow Pine and Johnson Creek effective at 8:00 a.m., August 14 as a precautionary measure (see attached Proclamation).
Residents will be escorted in caravan fashion over Lick Creek Road from Yellow Pine to McCall, Idaho at 11:00 a.m., August 14. The Red Cross has established an evacuation center at the LDS Church in McCall, Idaho for anyone needing a place to stay. The Red Cross is also working with the Sheriff’s Department and others to try to find accommodations for pets and livestock. The evacuation will remain in place until residents can safely return.
The evacuation will allow fire crews and engines for effectively prepare for structure protection without the added worry of private citizen traffic along roads and streets.
Trigger Points, locations previously established relative to the Riordan Fire advancement, are being reached and indicate a high probability that the fire may reach the Johnson Creek Road south of Yellow Pine. In order to protect homes and private property along this road and in Yellow Pine, fire tactics may necessitate a burn out operation to remove fuel from the advancing fire front.
Preparations for this burn out will begin tomorrow and are expected to take one or two days.
Riordan fire information is available at www.fs.fed.us/idahofires
I noticed the camera was down for maintenance.
