Backcountry Pilot • Jughead and motoadve Bridge gravel bar.
10 postsPage 1 of 1
Another fun gravel bar in Washington, flying with Jughead.
With cold air, much better performance , lightweight plane ,just pilot and 24 gallons,ground speed 41 kts very stable on short final, not bad for a 182 :)
Take offs were a lot shorter than usual too.
motoadve offline
Aircraft: Cessna 182P
CJ 6 Nanchang
Cessna 170B
Re: Jughead and motoadve Bridge gravel bar.
Hey, great footage!
That spot is very well known by local float plane pilots. For many of us that's the first place to practice when training for river operations. In the floatplane one always lands the other direction just a little up river so as to turn around before the shallows adjacent to your gravel bar.
Halestorm offline
Aircraft: C-182E Pponk
Big tires, we don't need no stinking big tires. :D
Way to go Jughead! Nice and slow! Luv it... =D> =D> =D>
www.avthreads.com
bigrenna wrote:Way to go Jughead! Nice and slow! Luv it... =D> =D> =D>
He is good, agreed =D> =D> =D>
motoadve offline
CJ 6 Nanchang
Cessna 170B
Looks like a stock leading edge on the wing too, no STOL cuff ???
EZFlap offline
Nice landing and takeoff. What about a rudder turn in low ground effect to miss the trees on the right bank and go down the middle of the river? Why go over something you can go around?
Nice energy management turn to make the turn in the river.
contactflying wrote:Nice landing and takeoff. What about a rudder turn in low ground effect to miss the trees on the right bank and go down the middle of the river? Why go over something you can go around?
The bridge, he had to climb and turn away to avoid the bridge. It's best to stay as far away from people when you're doing this sort of stuff... I would have done the exact same thing.
Looked like a good example of a stabilized approach. =D>
Different strips - different approaches. 8)
Chris C
wannabe offline
53 C-170-B+
Yes, the wing is completely stock with the exception of some mine ding's on the left leading edge from it's previous life in Alaska. Stock O-300 with a 80-46 prop. I was carrying 20 gals of fuel, no back seat, probably 15 pounds of gear in the back.
jugheadF15 offline
Contributing author
10 postsPage 1 of 1
