whynotfly wrote:I want to purchased one of these portable jump starting units to carry in my plane in case I find myself with a hard starting engine and a worn down battery in a remote spot. I'm not a real wiz when it comes to electrical topics so I thought I would ask you folks before I shell out $$ for something. Having done a little bit of searching it seems I have two basic type choices, the somewhat bulky ones you find at your neighborhood auto parts store and then the new lightweight lithium units. My plane is a 59 172 with a newer Lycoming 0360 A1A which uses an alternator verses the original generator. It is a 14 volt system. I am a little wary of the lithium type due to possible fire hazard. Are my worries valid? I am leaning towards getting one of the regular automotive type with 1000 amp available for jump starting (about $80-90 with weight of 18lbs) which I could carry in the baggage compartment. I would appreciate any input from those who have used these or carry one of these in their plane. Thank you in advance. John
PAMR MX wrote:Well hand propping is one thing flying home is a another.
Left the master on once when flying through BC Canada. It was an O300 in my 172. It started right up hand propping. The problem was my destination was a towered airport. The 172 had an alternator so I still had no power/ radios. I had to land at an uncontrolled airport and still find someone to jump start the plane.
wannabe wrote:...Second one turned out to be a 737 on downwind as I was coming back in on the 45. ...
CamTom12 wrote:Alternators require a voltage to energize the field. Otherwise they won't work. If the battery is too low to supply this, you need an external power source to light off the alternator.
