Oregon180 wrote:Is it cause for concern that all those holes are perforating the spar at the very point of highest stress?
gbflyer wrote:You can get to some of the info through http://www.justkitplanes.com Not sure what gives with the company site, I can't get it either.
Speaking of the Highlander, I wonder if someone who has built one would chime in here and talk to me about if they are actually pop - riveting the strut fittings to the spar as depicted in one of the build pics and what are the rivets they are using.
From justkitplanes.com build pics:
gb
Zane wrote:What's the verdict on the wood ribs?
EZFlap wrote:Zane wrote:What's the verdict on the wood ribs?
No biggie, they're pretty thick Birch plywood, maybe 3/8" or more. They're a little more work than aluminum ribs because you have to go and hand-varnish them with epoxy, but if designed properly they are plenty strong. Sawn plywood ribs are not quite as light as built-up ribs made out of a dozen pieces of 1/4" square Spruce. But they are easier to make and when designed properly they are very strong. They are also likely more resistant to damage from handling/hangar rash as well, because of the plywood's bending resistance. As mentioned, thousands of KF/Avid airplanes flying around.
Warning: Slightly off-topic but still relevant to this subject IMHO
The one and only weak spot, in my opinion as a semi-educated, non-engineer sideline observer, is that aluminum does not like to be glued. No matter how well you clean it, a microscopic layer of oxide forms within seconds, and you are actually trying to glue to that oxide layer. I was informed (by a scientific chemist type person who knows far more than I) that you will get about 20% bond strength that way, meaning 20% of the strength of the base metal.
Now if you design for that by shaping the ribs with rounded cutouts that wrap halfway around the alum. tube, and/or putting the glue joints under loads that are more favorable (i. e. not "peeling loads") it is relatively safe. This wing design has the tube spars being "pulled" together by the fabric and any compression struts or diagonals, pulling the spars into the rounded rib cutouts. This helps greatly. But you still have the possibility lurking that the oxidation layer can start to creep under the epoxy over time and weaken it. So you need to inspect for this type of de-bonding at annual and you need to strip and recover at some interval even if the fabric is good.
There are two main factors to remember IMHO when bonding aluminum:
1) Big Aerospace does it all the time, with honeycomb and structural bonding and plenty of glued aluminum joints, even on small airplanes like the Grumman's AA-1 and AA-5. But they have special facilities and methods not available to homebuilders.
2) Homebuilders have a poor record of being able to accomplish bonded aluminum safely, we've lost a few Monnett Monerai and Moni aircraft, and Schreder HP series gliders... because you cannot reliably create the environment for bonding in your garage.
However, there's something you CAN do easily to solve this problem if you are building with bonding to aluminum, which is why I am ranting about it here on a Highlander thread. There are certain types of conversion coating (Alodine type wash coatings) that make the surface of aluminum into something that DOES like to be glued. These conversion coatings actually change the chemistry of aluminum in the outer surface layer. It was reported that after the conversion you will get 80% bond strength, which is as good or better than a riveted joint.
So one fact is that there are thousands of KF/Avid airplanes flying safely without the conversion coatings, but IMHO they need to be inspected for creeping bond failures on a regular basis, the same way as you inspect for dry rot and worn rivets and rusted steel tubes. And the other fact is IMHO that if you are building an airplane with glued aluminum, doing the conversion coating before bonding is a very cheap and simple method of getting far better strength and reducing the likelihood of bond failures. You also get permanent corrosion proofing as a side benefit.
