Here's a neat sounding aircraft:
http://www.katmai-260se.com/performance.html
Anyone have experience with these planes in the wild?
tom
Performance
The Katmai and the 260SE take off and land short and display the same safe flat attitude after liftoff. No unsafe high angles of attack here, even with a 4,500 foot density altitude. Most pilots would agree that the high angle of attack, and "hang-on-the-prop" type of performance is absolutely dangerous. If a power failure or wind sheer should occur during operation in the STOL mode it could be disastrous. This is the trade-off for other STOL aircraft. Only the Katmai and the 260SE can fly safely while in the STOL mode.
Both of these aircraft have the ability to safely execute a forced landing during a STOL takeoff. Compare this to the fatalities that would surely result from this happening to a conventional STOL aircraft that hangs on the prop.
