EZFlap wrote:The 85 or 100 HP Taylorcraft is a larger, safer, more well engineered airplane, with several advantages and a few disadvantages compared to the Kitfox. and one HUGE advantage in the back country.
The T-Craft is larger??? A bigger wing for sure, (at least in span, chord is similar to a S-7), but the cockpit is cramped compared to my Rans S7-S, (though comparing any tandem to a side by side is apples to oranges) no overhead viz either (no skylight), out to the side a taller pilot is looking at the wing root, I'm looking out the window, over the front is also better in the S7-S. Gross weight is 132 lbs more then my old BC12-D (65 hp). I built an '88 Model 1 Kitfox, and had a ball for 650 trouble frees hours, a two stroke no less. My T-Craft, after I built new wings for it, was also a joy. It was my first, only, and last certified airplane, I've experienced the total freedom of building and flying experimentals too long. I flew my first Rans S-7 (short tail), 1300 hrs all over the Idaho back country and the western US, all trouble free, with a frigging Subaru conversion no less. I am now 300 hours into my 912S in my second Rans, and it is very similar (but better) to what a T-Craft with a O-200 is performance wise, a buddy from the Burley area had one and we flew together quite a bit when I had the Soob S-7. I would outperform him in takeoff and climb, he'd out cruise me but used 1 1/2 to 2 GPH more fuel, I can't remember if he had to use av gas or not, I used regular mo gas. Tubing sizes on the S-7 are very similar to the T Cart, I've seen them both naked, and its brand new tubing not older then me.
I did feel very safe in my T-Craft, I figured, hell, it'd been in the air since '46, what're the odds its going to drop out of the sky today! Whether it was ACTUALLY safer is dependant on many factors, factors 50 plus year old. No question it is a proven design, but at this point both the Kitfox and its derivitives, and the Rans S-7 designs have been around for 20 plus years with a proven airframe history, and an excellcent one at that.
All of us flying the back country in our 912S powered aircraft are chuckling, you are a wee bit harsh in your assessment, it can't be ALL bad as it is the engine of choice for the Predator and other military drones, NOT the 0-200.
Enough defending homebuilts and the Rotax, that discussion will never end, you are either for 'em or against 'em: I DO agree the T-Craft may very well be the best bang for the buck, and will, due to the lack of flaps, sure teach a guy in a hurry accurate airspeed control and proper use of the rudder! I'd be looking for an F-19, they're out there, they won't out STOL a VG equipped 100 horse Rotax powered S-7S, and the operating cost will be a bit higher (high GPH and cert related requirements), but a great airplane for the cost, I was real impressed with what my 65 powered one could do, especially the rare time I had it at sea level. I DO like the fact that my S7-S does what it does with a 29' plus span as opposed to a 36' span, simply from a practical point, pushing it around the hanger, landing on fence lined dirt roads etc. Long live the T-Craft....!
