What is a better techinque coming high and at an angle or flat and reduce power while passing the onstacles?
What other tips techniques are there?
Went practicing today and Im not convinced Im doing it right.
Coyote wrote:.... As you will see there is much greater room for error on the steep approach as you can always push forward on the stick if you get too slow. As you approach stall in a flat trajectory it requires combined application of power and forward pressure which is alittle more difficult all while the trees are at your feet. One thing that is hard to appreciate is that if you want to steepen the approach pull back on the stick ........
hotrod150 wrote:Coyote wrote:.... As you will see there is much greater room for error on the steep approach as you can always push forward on the stick if you get too slow. As you approach stall in a flat trajectory it requires combined application of power and forward pressure which is alittle more difficult all while the trees are at your feet. One thing that is hard to appreciate is that if you want to steepen the approach pull back on the stick ........
I agree. Counter-intuitive to pull back on the stick to descent but it works. Also agree on more rrom for error. The nose-high attitude can make for poor visibility, esp if you're worried about deer or whatever running out in front of you. (some of them seem suicidal)
Coyote wrote:I have just 3 recommendations: airspeed, airspeed, and airspeed. Practice flat trajectory and steep approaches at very slow approach speeds at a no obsticle airport. As you will see there is much greater room for error on the steep approach as you can always push forward on the stick if you get too slow. As you approach stall in a flat trajectory it requires combined application of power and forward pressure which is alittle more difficult all while the trees are at your feet. One thing that is hard to appreciate is that if you want to steepen the approach pull back on the stick but not so much the approach is straight down. On your first attempt at this strip wait for a good onshore breeze to help you. Steve
