larger tires for 172
The Type Cerificate 3A-17 covers 175's, 172 Powermatics, T41's and Hawk XP's. They are all derived from the 175 just changed the names because of the problems with the geard O-300 Engine.
Jaerl offline
1423
- FindMeSpot URL: http://share.findmespot.com/shared/face ... Q0xkBgMvPi
GroundLooper wrote:From a 1969-1976 cesssna 172 service manual. Did a search for Cessna 172 service manual through google and found this.
So if you need a field approval for 800x6 on the mains would you then need a field approval for 600x6--6 ply on the mains because the equipment list says 4 ply.
3633
- FindMeSpot URL: http://share.findmespot.com/shared/face ... I5tqEOk0rc
- Aircraft: Cessna 182
Jaerl wrote:The Type Cerificate 3A-17 covers 175's, 172 Powermatics, T41's and Hawk XP's. They are all derived from the 175 just changed the names because of the problems with the geard O-300 Engine.
All this time I thought the T-41 was just a jazed up 172. And the Hawk XP was a high powered 172. So does that mean that a 175 is just a 172 with bigger tanks and a geared engine.
3633
No I think there are some structural beef-ups as well. I read somewhere about a thicker shear web in the wing spar, but I am not 100% dead nuts certain of it.
2226
qmdv wrote:GroundLooper wrote:From a 1969-1976 cesssna 172 service manual. Did a search for Cessna 172 service manual through google and found this.
No. There are no plys in tires anymore. It is ply rating. You need a minimum 4 ply rating tire. A six ply rating tire will handle more weight but will weigh more itself.
Bonanza Man offline
909
Sooo
........ahhh
.......oh sheeesh
](/phpbb3/images/smilies/eusa_wall.gif)
....never mind
5297
There is a T-41 based on the 172.The T-41 based on the 175 uses the IO-360 6cyl Continental same as the HawkXP.The Hawk XP is a late model 175,type certificate 3A-17.As far as I know the wing is the same as a 172 just bigger tanks(same as long-range 172)Gross wt on 175s is higher.Lots of engine stc's all the way to 0-470.I have a whole plane dis-assembled.
Bill
willyb offline
167
qmdv wrote:BM. It does not say 4 ply rating minimum. It says 4 ply rating.
Just being a prick about this.
tim
Does this mean FAA inspectors all fly cessnas too?
GroundLooper offline
1168
BCP Poser.
