Backcountry Pilot • Latest must have Backcountry Gear
33 postsPage 2 of 21, 2
Re: Latest must have Backcountry Gear
Its going to be hard to get a fieldaprovel. A lot of paper work is involved. Need one on each side for him and her flight pooper. This is great. Need one with the auto rising lid .. =D>
Ken in Alaska
akflyer2001 offline
qmdv wrote:I call it the EZ FLOP I have been working on this for some time now. My lawyer brother asures me that there is no copywright infringment to worry about. I need to do some work on the plane so I am sure that swift sales of this must need product will help.
For the three tree huggers on this site, you simply put a small buckegt under it with plastic bag so you can haul it out.
Bush wheel model coming soon.
Is that on your equipment list as a one or 2 hole'er --What the weight and balance data ?
182 STOL driver offline
Hey Bill, if anybody can get a fireld aproval for this it woulod be you :D
This is smart. I imagine it would be quite windy, but at low power perhaps it wouldn't be too bad. You'd certainly want be confident your autopilot was properly operational.
pitfield offline
Don't forget the requisite placarding. To wit:
1) No smoking.
2) In the event of severe turbulence, close lid and exit waste production area immediately.
3) Please notify flight attendant should you have difficulty using these facilities.
4)
Mister701 offline
Aircraft: Rans S7LS
qmdv wrote:
Jumpy wrote:Can you raise the seat for when you're just taking a piss?
Yes, for all models but the Maule. They squat to pee.
Goin' straight to Hell fer that one!!
Hottshot offline
Wup Winn
541-263-2968
Joseph Or, 97846
www.backcountryconnection.com
Sorry. Come to think of it, you are the one that told me about Maule owners prefered position when voiding. Maybe it was Rob. :D
"Yes, for all models but the Maule. They squat to pee."
Cause they don't want to embarass the other pilots
175 magnum offline
qmdv wrote:
Hottshot wrote:
qmdv wrote:Can you raise the seat for when you're just taking a piss?
Only problem is the water is cold on the hose. #-o
175 magnum wrote:"Yes, for all models but the Maule. They squat to pee."
I should have known. I should have put it all togeth cus MAGNUM is in you user name. 175mm is about average. :D
tim
Before the EPA was around to protect us all there was an option on a motor home that I owned. I called it the inturderator. Simple device that used a blender type unit to chop up all the "solids" as the whole slurry was pumped into the exhaust as you were traveling down the road. Yes, it's true. You slowly pumped your s&%t into your exhaust while sight seeing and it incinerated it. Well, probably not but at least it warmed it up some before launching it out the pipe.
With that in mind, might I suggest that the in flight version proposed by EZ Flap, drain into a "french pipe" like one of the members here has.
Mr. Ed offline
Tim Do you think this will be offered in a bidet model :mrgreen:
Maybe Rob could get this version in the Maul
Glidergeek offline
Aircraft: 1968 P206C
DG 400
And Tim, for goodness sakes, move the dog UP-stream of that device. I don't know how many friends you have left at this point, but that dog is likely the best one you ever had so treat him right #-o
In order to "frame" the picture correctly, move one of your Obama campaign posters into the position slightly downstream of the device in the photo.
