Noe Flightrisk wrote:Now that I'm using bushwheels in short, obstacle-rich off-airport situations, I've begun to appreciate "the bush pilot landing" technique: three-point at touchdown for minimum speed, then tail up for visibility, and maximum braking. Without getting the tail up, it is impossible to keep the the planned rollout path in sight and dodge the obstacles. But what is the best way to perfect the technique--learn to increase braking force on wheel landings, or learn to reduce up elevator on 3-point landings with maximum braking? Besides continuing to practice, practice, practice, have you any tips to improve pitch and yaw control during rollout?
akflyer2001 wrote:Some thing to remember, keep the yoke in your lap after touchdown. If you don't and apply the brakes you will nose over. Its a good thing to remember. So many people slack on the yoke after touchdown. When I touch down I dump the flaps as well.
Ken
qmdv wrote:akflyer2001 wrote:Some thing to remember, keep the yoke in your lap after touchdown. If you don't and apply the brakes you will nose over. Its a good thing to remember. So many people slack on the yoke after touchdown. When I touch down I dump the flaps as well.
Ken
I have a nose wheel and do not dump flaps on touchdown. I like the drag to help slow down. Most of my landing are on grass and that works good for slowing down too. Should be same with tailwheel.
I can't seem to brake hard enough to get the tail up until I've bled off considerable speed
