Backcountry Pilot • LED wing lights for Cessna Horton leading edge
10 posts • Page 1 of 1
Does anyone know a source for wingtips with landing lights for installation on a 182 with the Horton STOL kit?
Neither the Sene Quasar CX or Knots2u RD-9000 have tips that can be used on the Horton cuff without some creative ingenuity.
Thanks!
AK737Pilot offline
Aircraft: Cessna 182L
Re: LED wing lights for Cessna Horton leading edge
Just looking at the knots-2-u tips on their website, on the options page it asks to specify either sportsman or Horton kit. Might be worth a call to those guys and see what’s involved with installing on a Horton.
It was common years ago to end whatever cuff one was installing about an inch short of the end of the wing and fabricate a little blank off plate. You would then just keep your original wingtips.
Halestorm offline
Aircraft: C-182E Pponk
Thanks for the reply
Yeah, last week I saw the blurb to indicate if it was a Horton cuff, so I tried ordering a set. Today they emailed me and said it’s not available.
I’ve seen a couple of those mismatched leading edge installations. I was hoping for a more plug-n play solution.
AK737Pilot offline
I run the Quasar tips on my 180 with Horton cuff. However I changed the tips back to stock. Horton officially does not change the aircrafts speeds. Has not been an issue for 5 years.
CYQQ offline
Aircraft: C-180H
That’s exactly what I’ve been looking for!
Where did you get that little fairing at the end of the cuff?
AK737Pilot offline
AK737Pilot wrote:Where did you get that little fairing at the end of the cuff?
Thats what I was talking about in my post, we would just fabricate a little sheet metal end to the cuff and then install the stock profile tips.
Halestorm offline
Perfect!
Quasar CX tips ordered! Time to put my fabrication [non]skills to work. :lol:
AK737Pilot offline
AK737Pilot wrote:Does anyone know a source for wingtips with landing lights for installation on a 182 with the Horton STOL kit?
Thanks!
i learned this the hard way. once it was torn apart at Beegles and we realized it wasnt a fit (Wing X might also be to blame) we sent them back to Sene and they modified them to the correct dimensions, WA LA
clappedout180 offline
Aircraft: 1977 C180K
The little cuff was on my wing with the Horton. I can try for a better pic for you with detail.
CYQQ offline
Aircraft: C-180H
CYQQ wrote:The little cuff was on my wing with the Horton. I can try for a better pic for you with detail.
That would be great if you wouldn’t mind posting a few pictures! Thanks!
AK737Pilot offline
