One case in point might be the recent AOPA article about Syn Vis on the ipad. They mention the little portable AHRS. Just two screws to attach it to the floor of the Husky. Well, didn't that just become a part of the airplane and not portable. 337? I doubt it. They also mention Wi Fi (maybe they meant Bluetooth)
Wi Fi attached to the plane was most likely not approved. I know one shop at Van Nuys who get their FSDO to sign off Wi Fi. The rest of the country... good luck. A portable Garmin stuck in one of those plastic docks we all see. I have seen 337's for the dock. OK, good so far. Now, what about that little set of wires from the Garmin portables over to the transponder? Looks like hard wiring into the system to me. Does it still meet the rules of portable? What is the point of my rant? It is this: There are a myriad of products out there that work well and arguably could save your bacon in tough conditions. Little companies can't afford the $7 mil for example that the first syn vis company spent to get certified and on an AML. So, the non-experimental crowd either goes without.... or enters the gray area to hope they don't get ramp checked.
At Copperstate last year, I saw a beautiful Dynon in the panel of a C180. No backup instruments anywhere to be seen. I am sure it worked great... but was completely illegal. If the FAA has hearburn with certified planes and feels experimental is the answer, then let us all apply for experimental on our planes and put on the appropriate placards and warnings. Case closed. Neighbor wants to fly with you...let them read the warning and buckle up. What do you guys
think out there?
Wiping my screen clean now.
