Wa180 wrote:...Here’s weight, COG, and arm from the last change we did; 1748.68 32.64 57,072.21... I hope someone can find an error in my calcs because that would be really helpful!
It's hard to say w/out seeing the bird in person and looking it all over. But one easy upgrade that helps with C.G. is to go with the ABI wide fork and run the 400x4 tire/tube. This is about 3 lbs heavier than stock and gives you about 1 more inch of total arm aft.
With respect to your question, I would say:
1) anytime I see a W&B where the mech lists the weight out two decimal points causes me to scratch my head. First that degree of accuracy wont make a lick of difference, and second it tends to induce all kinds errors downstream. That alone would make me want to weigh the bird again.
2) I have seen all kinds of errors in all knids of places... not just with math. I just weighed a Skywgaon where the numbers added up, but didnt make any sense. The last mech didnt apply a "common sense" test to his figures. Turns out he had used a measurement of 22" aft of the datum for the tires rather than 18", and a TW measurement 5 ish" shorter than it measured out when I plumbed the bird on the floor. This caused a 4" aft error in the C.G. If it seems weird, it usually is.
3) W/out looking at the bird, my gut says that such a FWD C.G. seems wrong. The envelope for your bird is 34.5" - 45.8". At 32.64, you are not legal at all. Lets say you are 200 lbs sitting at Sta. 36... With only unusable, you are illegal at 32.97. Now add 20 gal... 33.13 (still out.) You get where Im going. If the numbers are right, you would not get legal until you had at least 37 gal of fuel in the wings.
Here is a common sense test:
For reference, I have a 1966 180H. The orig WB sheet from Cessna (below) weighed in at 1632 with a C.G. of 35.9. You report the C.G. at 32.64. In order to get the C.G. of my orig. airplane to shift that far forward, I would have to gut 80 lbs out of Sta. 100. (roughly the standard rear baggage.) Impossible right?
I did some pretty heavy dieting on my bird. On 8.5x6 tires, she is 1744 lbs. This is my "utility" weight w/ no rear seats etc... The bird has fwd battery, no interior, wingX, Sprotsman, etc etc etc... I consider it very light for an H model considering its got most of the "bush" mods a fool could waste his money on. The C.G. is 36.01, which is 0.1" away from Cessna's orig calculation.
I guess what I am saying is that the numbers dont "seem" to be right... but that doesnt mean they arent. Certainly grounds for a closer look.
Again, Im not yapping about all of this for any particular reason other than to bring awareness to what these mods may or may not do. Im in the middle of an engine swap which is going to add much more weight in the wrong direction. SPW engine mt, back to orig starter, 2-3 blade MT, air/oil sep, heavier mags (Shower of Spks,) etc... which will move the C.G. a bit more FWD.
If all else fails and you dont want to bother with any of this... you can always just pick up one of my T's (Below.) I hear it makes everything work out fine.
https://www.avthreads.com/products/if-it-fits-itll-fly-mens-t?variant=18788707845
This is the Scale Sheet I made that I use when I weigh birds. It lays out how Cessna wants you to do it.
