Light weight starter
I have noticed that my starter seems do be dragging pretty hard. Somtimes it just growls with no engine movement. I will probably change the starter prior to doing much flying this summer.
Anybody have any experience with the Skytech light weight starter. They are a couple hundred bucks more than an overhauled one. $510.00 at chief.
3633
- FindMeSpot URL: http://share.findmespot.com/shared/face ... I5tqEOk0rc
- Aircraft: Cessna 182
Tim, sounds like your starter drive is slipping.
2313
qmdv wrote:Anybody have any experience with the Skytech light weight starter.
We put one on my 172 and it works well for us.
Okie Bush Man offline
153
qmdv wrote:I have noticed that my starter seems do be dragging pretty hard. Somtimes it just growls with no engine movement. I will probably change the starter prior to doing much flying this summer.
I have one on my 182. Works like a champ, spins up faster, 6 pounds lighter. Bought it through Chief a couple years ago.
C ya, Bub
Skylane offline
569
Not all reviews are so shiny. According to the Cessna forums I frequent, many guys are replacing starter adapters at 200 and some hours....requires engine lift from mount to access starter adapter. At about $1500 a pop, it can be annoying. The isssue seems to be the earlier light weights gear system would not allow the internal spring to "relax". certain types/brands of oil seem to have agravated the problem. I hear the newer starters have been adapted to allow the spring to relax. Might want to check out Niagra Airparts web site...for a primer on the issue,. this is assuming you are talking 470 on your 182....
n2485q offline
70
Bill White
N2485Q
Twin Bridges, MT
Before replacing starter:
1) make sure battery is up to snuff- fluid, charged, not too old, check voltage
2) clean up all electrical connections- not just on the outside, take them apart & clean the contact surfaces
3) check condition of the brushes in the starter- brushes are a lot cheaper to replace than the whole starter
The starter on my C-145 was kinda dragging & all of the above needed attention. Worked fine afterward.
10534
Wed May 07, 2008 11:06 am
Tim, mine has been fine ,like the weight savings on the front end.
Bruce
bmuggoch offline
34
Done it all but the brushes. Pullin the starter tomarrow. I will put in brushes fefore I buy a new starter. If there is a lot of end play in armature, then I think a light weight starter before a rebuild exchange.
3633
