Backcountry Pilot • LOOKING FOR A USED AIRGLASS/LANDIS OR HD NOSE FORK
5 postsPage 1 of 1
I have tried this once before but I thought I would give it another shot. I have a straight tail 182 and I would like to find a larger nose fork. I am also looking for a 6" nose wheel for the same project. I know the Landis is the best way to go due to (stc) but I would still entertain a 310 or 206 nose fork if anyone has one available.
I also have questions about brake upgrades to dual piston calipers. Open to suggestion if this is needed or if stock will do fine. I plan on running 8.00 or 8.50 x 6" mains and 7.00 x 6" front tire and wheel.
Any suggestion's or pit falls to stay away from would be much appreciated.
Happy Holliday's to all......
ZBDRACE offline
Aircraft: CESSNA 182a
Re: LOOKING FOR A USED AIRGLASS/LANDIS OR HD NOSE FORK
If you go used Airglas, be sure you can read the serial number even better be provided with aircraft N number it came from. You will then sweet talk your way to a transferred STC with Airglas.
If you buy the 310/206 fork, get the attachment block with it or it may be impossible to find one. Axles are out there but few and far between.
All other info has been discussed ad nauseam......
skyward II offline
If you are still looking for a 310 cessna nose fork I have one entire assembly including the wheel. Wheel is damaged in the valve stem side. Located Washington State.
BushFlyer-182B offline
Aircraft: Cessna 182B
Cessna 182E project
BushFlyer-182B wrote:If you are still looking for a 310 cessna nose fork I have one entire assembly including the wheel. Wheel is damaged in the valve stem side. Located Washington State.
If ZBD doesn't take you up on it I'm interested.
mathiasrust offline
Aircraft: C182A
Yes interested in nose fork. just sent PM
ZBDRACE offline
5 postsPage 1 of 1
