Looking to buy a H/D Nose Fork for a 172
Wed Dec 01, 2021 11:41 am
I'm looking to buy a heavy duty nose fork, including axel and 6-inch wheel to install on a C-172. One from a C-206, 310 etc... If you know of one for sale please PM me. Thanks.
alaskan9974 offline
93
Wed Dec 01, 2021 12:24 pm
skyward II offline
447
alaskan9974 offline
93
myers aviation in oshkosh wi has a fork
Barrakudaman offline
157
- Aircraft: 1960 Cessna 182
alaskan9974 wrote:I'm looking to buy a heavy duty nose fork, including axel and 6-inch wheel to install on a C-172. One from a C-206, 310 etc... If you know of one for sale please PM me. Thanks.
What year is the 172. Was it optional equipment or do you need a field approval?
3633
- FindMeSpot URL: http://share.findmespot.com/shared/face ... I5tqEOk0rc
- Aircraft: Cessna 182
qmdv posed a valid question. A couple of years ago I found a HD fork with wheel and tire assembly. Since my plane at the time was a 1960 172A and the HD fork was not on the list, it would have needed approval. In the end, it would have been nearly as expensive as getting the Airglas fork, which is actually the better option. I think the HD fork can only use up to a 7.00-6 tire.
2036
- Aircraft: RANS S-7
skyward II on Sun Dec 05, 2021 10:07 pm, edited 1 time in total.
skyward II offline
447
Sat Dec 04, 2021 10:16 am
skyward II wrote:WWhunter wrote:qmdv posed a valid question. A couple of years ago I found a HD fork with wheel and tire assembly. Since my plane at the time was a 1960 172A and the HD fork was not on the list, it would have needed approval. In the end, it would have been nearly as expensive as getting the Airglas fork, which is actually the better option. I think the HD fork can only use up to a 7.00-6 tire.
6” is perfect size for nosewheel, 8” mains. I would not go any larger.
Are you saying 6.00 is perfect and 8.00 for the mains? 6" is the wheel size... I run a 7.00 and 8.50s on the mains and would not go any smaller for the flying I do.
5186
skyward II on Sun Dec 05, 2021 10:16 pm, edited 2 times in total.
skyward II offline
447
I ran a 8.50-6 nose and 31” mains. It worked awesome for what I was doing up here in AK. 31” is overkill but I didn’t sink in soft stuff like the 8.50’s would. The airplane had a 207 fork and 7.00-6 nose the Airglas with a 8.50-6 was a huge difference in soft places.
There are several heavy duty forks for sale on anc Craigslist
AKCFI offline
1
- Aircraft: 108-1
Tue Dec 07, 2021 12:24 pm
Thanks, I bought one from skyward that day. My plane had an approved FA for a HD fork in the past so I was planning on using a 7.00 and 8.50 smooth dessers. Its a M model. I mainly just use gravel bars in the summer, nothing too wild with it.
alaskan9974 offline
93
