Backcountry Pilot • "Lost"Twin Sea Plane Type?
4 postsPage 1 of 1
Some years ago I came across some Specsheets about OLD airplanes. This may have been from the 30's, One was a fibergalass (I think) twin with engines small enough I'm sure flight would not continue on just one.
Perhaps 65-125 Hp?
The design owner was a engineering firm from the Tucson Az area who just happened to put the rights to it up for sale just after I found the sheet.
I think only one or two were ever made.
After all these years Im wondering what ever became of it and if anyone ever took on the project?
Goldinthecreek offline
Re: "Lost"Twin Sea Plane Type?
It seems like it was a high wing 4 seater with the engines embedded in the wing.
If it was in the 1930s it probably wasn't fiberglass. There is a newer composure seasonable design called the Gweduck. You can see the detail here: https://www.gweduck.com/index.html
Seems like it was 30s or 40s definitely not the gweduck.
Old enough a twin didn’t need a engine out Climb rate.
4 postsPage 1 of 1
