Airplaneflyer wrote: I’m not sure if the 2 notches is a 170 thing, that’s what my instructor taught me for wheelers if I’m not trying to land short, and I’m kinda stuck with it. I don’t get much effect out of my flaps on the ‘48 170. Later models had much bigger flaps. I have learned to slow my landings down, mostly because people here pointed it out.
I owned a ragwing 170 for about 11 years, and put about 1700 hours on it.
I did the flaps just like I did later in my C150TD and my current C180:
1/2 flaps for takeoff (100% of the time) and full flaps for landing (about 95% of the time).
Yeah, they're smaller and less effective than the big barndoor flaps,
but they provide the same benefits- just a little less so.
I went for a ride with someone I know recently in his C150TD,
I was surprised that he didn't use any flaps for takeoff,
and either no flaps or only 20 degrees (can't remember) for landing.
Just because your instructor taught you to use only 2 notches for landing doesn't mean you're stuck with doing that for the rest of your life.
Experiment a little, try different techniques.
FWIW here's an excerpt from an article about wheel landing (and a critical afternote) written by Bill White many years ago,
even if you don't treat it as gospel it is a pretty good place to start.
"Here's the technique: Get established on final. At 1 mile out you should be
at 60 knots IAS (depending on wind conditions), 500 feet above the
runway and descending at 500 FPM carrying about 13"-14" MP with
full flaps. Trimmed to hands off. The aircraft should come over the
threshold almost level. Do not flair and do not pull your power until you
'feel' the wheels touch (resist the temptation). This has to be learned
because your natural instinct is always to pull power. Almost
simultaneously when you pull power at wheel contact, come on with as
much brakes as you need and hold neutral yoke. The torque from
braking will help keep the tail up. Then as the speed is reduced and the
tail settles come back with the yoke. Power controls rate of descent, if
you reduce your power your descent rate will increase (even at 2'), then you'll have
to flair to compensate and you'll be chasing the airplane. You want as few
changes to correct as possible. This technique takes out the guess work - if
you're low add power, if high reduce. Never change attitude or trim, it's simple.
A full stall landing has everything changing at the same time which
includes: power, speed, attitude, yoke, visibility and pitch. This is not as
predictable because you're waiting for things to happen, you're chasing it."
" TO CLARIFY THIS GREAT TECHNIQUE. YOU TURN ON FINAL APPROX 1 MILE OUT
ADD FULL FLAPS AND REDUCE THROTTLE TO 12"-14" TO GET 500 FPM DECENT AT 60
KTS INDICATED (65 IF ITS WINDY). THE AIRCRAFT IS TRIMMED TO A LEVEL
ATTITUDE. YOU'RE PLANE IS PARALLEL TO THE GROUND (HORIZONTAL) ALL THE WAY
DOWN FINAL AND THERE'S NOTHING TO DO BUT ENJOY THE RIDE, UNLESS THERES A
CROSSWIND TO CORRECT FOR. UNTIL YOU GET ABOUT 20' ABOVE THE RUNWAY THEN THE
ONLY THING YOU DO IS PULL (EASE ON) SLIGHT BACK PRESSURE FOR ONLY 3-4 SECONDS
AND RELEASE IT TO ASSUME ORIGINAL LEVEL ATTITUDE. THIS WILL LOWER YOUR
DECENT TO AROUND 200 FPM UNTIL TOUCHDOWN.
THE ONLY THING THAT CHANGED WAS YOUR RATE OF DECENT THE AT 20' AGL POINT.
THAT'S WHY THIS WORKS SO WELL. YOU'RE NEVER CHASING OR WAITING FOR ANYTHING
TO HAPPEN. YOU'RE IN COMPLETE CONTROL ALL THE WAY."
(from
http://www.young-river.com/c180/wheel.html )
