Backcountry Pilot • LSA Weight Limit Increasing To 3600 Pounds
23 posts • Page 2 of 2 • 1, 2
Re: LSA Weight Limit Increasing To 3600 Pounds
gtylerdowdy wrote:As we know now, it's (likely) not going to be 3600 lbs. They will be using a power index to determine the GW.....
Can you elaborate?
hotrod180 wrote: Can you elaborate?
Yes. The most recent article I can find on the subject is from Dan Johnson (very reputable). It's from July 19th, 2019. 3 months old. URL is below:
https://www.bydanjohnson.com/latest-upd ... /#comments
gtylerdowdy offline
Thanks for posting the link.
Here's a quote:
"Regarding the much-anticipated max weight increase, FAA refers to a “Power Index.” This term means a formula-based method to replace maximum takeoff weight in the definition of a LSA, involving wing area, horsepower, and takeoff weight".
Unfortunately this is vague in the extreme, gives no hint of what changes (if any) might be proposed.
Maybe certain limits on power loading & wing loading,
in which case we probably can not expect any increase in LSA performance over what we have now.
