Backcountry Pilot • mag dead / r/l?
mag dead / r/l?
8 postsPage 1 of 1
mag dead / r/l?
cessna 180 O-470R
mag went dead the other day in flight, when i turn it to "R" the engine quits, so does this mean that the right mag is dead? i been getting a few conflicting reports from guys on the field about this, some are saying my left mag is dead, not my right
LetsflyAK offline
Re: mag dead / r/l?
If the switch is on R, and the engine quits, the Right magneto has a problem. Or your ignition switch does.
Points, condenser, capacitor, P-lead interface, nylon distributor gear; All could be a trouble item that could render a mag dead. I'm experiencing this very fun right now too!
Re: mag dead / r/l?
ok, thats what one of my mechanics said, so looks like i need a 6310 slick rather then 2380 lol
i have a good feeling its my mag, its gone though quite a few hours
LetsflyAK offline
Re: mag dead / r/l?
Make sure you check that the leads going to the mag are indeed on the correct mag. Its a PIA to find out you changed the wrong mag because somebody didnt bother to hook up the p-leads correctly.
Jason
lostdutchman69 offline
Re: mag dead / r/l?
lostdutchman69 wrote:Make sure you check that the leads going to the mag are indeed on the correct mag. Its a PIA to find out you changed the wrong mag because somebody didnt bother to hook up the p-leads correctly.
Jason
#-o
Good call.
Re: mag dead / r/l?
I've just recently remedied magneto trouble with a lot of good help. I would recommend you contact Aircraft Magneto Service, Boeing Field, Seattle. They were extremely helpful to me in troubleshooting my Bendix 1200's :D , although they're well versed in everything else. Their background is aircraft accessories so they can tell you what else might be the trouble if it's not the mags. They have a troubleshooting guide published on their website called 'Is it the Mag?' The guide is listed in the sidebar. You'll find their website at :arrow: http://www.aircraftmagnetoservice.net/
TJ Carr offline
Re: mag dead / r/l?
IF it were me, I would consider disconnecting the right mag p lead at the magneto. Start the engine and check the mags.
If the engine still quits in the Right position, you have eliminated a grounded p lead or ignition switch as the problem.
That would be the easiest check.
If it still quits, I would then pull the magneto.
Good luck
Flyer
flyer offline
Aircraft: Cessna 182B
Re: mag dead / r/l?
Ditto the recommendation on making sure the p-lead isn't the problem. This is a pretty common thing to happen.
8 postsPage 1 of 1
