Backcountry Pilot • Manual Flaps Cessna 206
9 postsPage 1 of 1
I've searched some on the internet but haven't found an answer yet. Are there any Cessna 206 models with a johnson bar/manual flaps? I really enjoyed the manual flaps on my straight tail 182.
TxKiger offline
Aircraft: 182
Re: Manual Flaps Cessna 206
Nope, not that I am aware of.
Double post, sorry.
Dang, thank you for the quick replies!
TxKiger offline
Aircraft: 182
No, and you don’t want to go there, for many reasons. The best reason is if you learn to work those electric flaps, they work REALLY well.
I can't imagine the amount of torque it would take to pull those big flaps on. They work just fine with electric, and I really haven't found the need for manual of them. Just set 20 for takeoff and go.
Good to know! Thanks guys!
TxKiger offline
Aircraft: 182
FWIW, years ago in a 206 that was set up for off roading, we bootlegged a push button flap retract on the yoke. It let you keep a hand on the throttle and still get the weight on the wheels to shorten things up. It helped.
flyingzebra offline
flyingzebra wrote:FWIW, years ago in a 206 that was set up for off roading, we bootlegged a push button flap retract on the yoke. It let you keep a hand on the throttle and still get the weight on the wheels to shorten things up. It helped.
That's quick and easy on floats to shorten up landings---just reach over and flip the flap switch to "UP" as you flare......NO float in ground effect. Easy on wheels too, one of the benefits of electric flaps, actually.
9 postsPage 1 of 1
