Mars Rover Gravel Bar
Discuss your knowledge of airports and off-airport strips. Help inform other pilots of status, warnings, noise abatement, and closure endangerment. See also:
http://www.shortfield.com
Here's a shot from the Curiosity rover today, parked on an old streambed. Be cool to see a Cub in the background setting up for a water assisted landing.
4557
- Aircraft: Old Clunker
Thu Dec 20, 2012 10:43 pm
Forest, wheere did you find that pix. I check for new pix regularly and get the same ones and can't find new ones...
iceman offline
2026
Fri Dec 21, 2012 12:12 am
GumpAir wrote:Here's a shot from the Curiosity rover today, parked on an old streambed. Be cool to see a Cub in the background setting up for a water assisted landing.
I think it would be more reasonable to expect to see a liquid CO2 assisted landings. Unfortunately internal combustion engines need O2. BUT on Mars we have Hydrazine/peroxide powered O-360's... making 350hp and swinging 150" props in the rarefied atmosphere. Also ABW will have to adjust their rubber composition to deal with the - 100 C temps
exodus offline
229
iceman wrote:Forest, wheere did you find that pix. I check for new pix regularly and get the same ones and can't find new ones...
Butch, look on my Facebook page. I have the pic and NASA link there (can't snag it off my work computer)
4557
delete
wirsig on Thu Nov 29, 2018 6:24 am, edited 1 time in total.
wirsig offline
212
- Aircraft: Exp. Super Cub, Airbike Ultralight
Fri Dec 21, 2012 10:19 am
No little "marvin the martian" peeking around the corner of the photo-- what's up with that?
10534
Fri Dec 21, 2012 11:59 am
delete
wirsig offline
212
Ok, I say the rover is fake since it doesn't cast a shadow but there is one behind the cub.
dirtstrip offline
1455
Fat tires needed for Martian operations!
(Did you steal his Illudium PU-36 Explosive Space Modulator?)
1451
