Backcountry Pilot • Maule M-4 200 as a trainer
33 postsPage 2 of 21, 2
Re: Maule M-4 200 as a trainer
Littlecub wrote:
......check with guys here who have them.
Dammit, Gump, some of us that don't have to sell are very comfortable in our denial! Might have to check with a realist! :lol:
Back to the M-4.
STARTING in taildraggers is the best way to make sure a "pilot" finishes training and not an "airplane driver".......
IMHO.
Be sure to have someone who knows tube 'n fabric planes REAL well do the pre-buy for you. Fabric problems after the purchase is bad enough, but 'if', when you go to replace fabric, you find you have to replace a bunch of rusted tubes, too, well, that is not what you want!
Sounds like a good price if it is in 'actual' reasonable shape. After reading my comment above, you will probably 'discount' my opinion on price! :)
lc
Thanks for the thoughts, i fully get you idea on the pre-buy, that will be the challenge, find someone qualified to do the job
smorgan99 offline
Scott
79' TU206
maules.com wrote:The M4-220 has metal wings, so no issue there. The tail feathers are cheap to replace if needed and the tailcone is originally covered in Razorback which is tough stuff and very many of the M4s are still safely covered in it.
The hard paints of the day were prone to cracks.
The M4 145, 210, or 220hp will make a good primary trainer with excellent forward visibility, four doors, four seats, double baggage door (51"), 40 or 63 gallon fuel.
The early 145hp did not have copilot brakes but many have been updated.
She could accomplish PPL, conventional (taildragger), complex (cs prop and flaps), high performance (over 200hp) all in the same airplane plus have good speed and stol performance for Dad.
Jeremy
Thanks, someone said the gear is a bit narrow and not the forgiving, i like the idea of the many signoffs, what are your thoughts on the narrow gear?
smorgan99 offline
Scott
79' TU206
Its the same width gear Maule has always had. The same width as the ABW heavy duty gear.
The optional aluminium wide spring leaf type gear was introduced in 1997 as an option. It is 22" wider which makes it the same as the spread width as a C180/185 however this precludes landings on narrower pickup truck tracks and roads.
The wide gear is also 53lbs heavier than the oleo gear.
The Maule oleo gear is serviced with oil at annual time, springs are replaced if they lose resiliance, attach bolts should be torqued at annual as should any landing gear bolts.
The rumours you hear are because owners and mechanics are not paying attention to alignment and toein becomes too great thus making it a little more twitchy. Correct alignment and the gear is fine.
Jeremy
maules.com offline
Stinson v/s Maule,
The Stinson handles like a Mercedes....the Maule like a Jeep. And ......I love my Maule which I have owned for over nine years. Like others have said previously; little airplanes aren't worth much now but $20 grand for a 220 H.P. Maule just doesn't sound right.
bob
z3skybolt offline
Living the Dream
z3skybolt wrote:Stinson v/s Maule,
bob
Good thoughts on the difference, not sure of the real condition of this plane, been outside for sometime i expect and is a 1969 was is a repo
smorgan99 offline
Scott
79' TU206
I learned all my TW stuff in my M7 235HP, after the beginning of a ground loop on lesson 3 it has never happened again.
The Franklin 220HP is a sweet engine BUT!!! parts are an issue.
Good backcountry plane for you Scott.
Anything you buy that has sit, not pickled, be prepared to overhaul the engine. Not saying it will happen, just mentally and financially be prepared. Get it for a price that an overhaul won't make you upside down in the darn thing. Another option, agree on a price, on condition, tear down and fix anything not right right.
Even if it runs perfect, it might not be perfect.
I know a little about this. :(
Good day...Rob
I learned to fly in a Citabria, then transitioned into my M-5. I'm not particularly skilled and I don't have a lot of hours, but even so, I don't find anything about the ground handling of the Maule to be difficult or tricky under any of the conditions I've been in (no more, at any rate, than a Citabria or a 170), and I think it'd be a fine airplane to learn in.
JdS offline
Aircraft: Maule M-5-235C
Well,
My son who is about to turn 25 learned to fly riding around with me from the time he was a baby. As time went by we graduated to a 260 hp Skybolt and did lots of flying together. I wanted him to be proficient so we hired a friend to give him professional instruction in a C-150. At the age of 13 I soloed him. Well....I rode along as baggage: slid my seat back and closed my eyes. He made 3 perfect touch and go landings without a single comment from me.
Then I had a friend teach him in a Stinson....something closer to the Skybolt in performance. Later on we bought a Maule M-5-210-C about the time he turned 16 and had legally soloed. I then transitioned him into the Maule. He flew it perfecty and still does. A couple of times he has almost let it get away from him in a crosswind but managed to recover safely.
Not really an example of learning in a Maule....but he had zero problems transitioning. Every time we fly together I am amazed by his skill. He has a private with instrument rating and 250 hours, flies only a few hours each year but seems to maintain proficiency with ease. All about youth I guess.
Go for it!
Bob
z3skybolt offline
Living the Dream
Might as well learn to fly in a maule, they sound like great planes and if that's where you start, tailwheels are normal and it's no harder than any other airplane. By starting in a plane like that, she won't learn any bad habits about ignoring the rudder... I really want to get a ride in a maule, they sound like a whole lotta fun!
kevbot offline
z3skybolt wrote:Well,
Go for it!
Bob
Great story Bob and what a privilege to have enjoyed this kind of time with your son, i am hoping my story has a similar ending. Go for it seems to be the key, thanks for sharing that great piece.
smorgan99 offline
Scott
79' TU206
Thanks Rob, yeh the ground loop is the fear. I get the whole sitting around deal, have two stories about that, we can chat about them hopefully when i meet you on the 10th. Thanks for your thoughts.
Good day...Rob
smorgan99 offline
Scott
79' TU206
I learned to fly in the Maule and so has my wife,I think your daughter will be fine.
Hottshot offline
Wup Winn
541-263-2968
Joseph Or, 97846
www.backcountryconnection.com
smorgan99 wrote:
cstolaircraft wrote:right now I am training in a C-170B so I don't see why a tail wheel would be a problem. I think that it will make a better pilot out of you.
just my 2 cents
Reuben
Thanks, so you had no time before starting in a tail wheel?
Not that I was flying first lesson C-170B N3487C Now I am flying C-170B N8098A
cstolaircraft offline
