hotrod180 wrote:I think a field approval for a prop is gonna be much harder to get than for lets say larger tires.
The 2 blade C203 is a popular prop, esp in the 88" size--
people have tried to get a field approval to put one on a Ponk,
yet I don't think I've ever heard of anyone getting one.
And that prop is approved via the C180 TCDS for the 470K,
which has the same counterweight arrangement (four 6th order dampers) as the Ponk.
for the 470K,
180Marty wrote:for the 470K,
I'm pretty sure when my 470K was converted to the Pponk, two of the counterweights were changed. I now have two 6th, one 5th and one 4th and think that is what the 470U also has. I can tell you that it is a smoother engine changing from four 6th orders.
180driver wrote:Ok smart prop guys. It is possible to field approve a McCauley C50 prop (82” 2 blade) on a Pponk 520?
If not and I can’t afford a brand new prop, what is the best 2 blade option? My priority is more cruise speed over climb.
Thanks.
hotrod180 wrote:A buddy of mine has an 86" C66 on a ponked 54 model.
Field approved, with engineering data provided by Knopp.
I can provide scans of the paperwork if you find a C66 & need it.
C180_guy wrote:Also an issue for the Norland IO470 and C203 Mac. It was difficult many years ago to work with the engineering office for a field approval using the C203.
Scolopax wrote:The big issue that I ran in to, when talking with the FAA about approving the C203 on the -59 was the horsepower limit. Not sure that’s the case with the three blade, but I wouldn’t expect a slam dunk if it hasn’t been done before.
C180_guy wrote:P.9 of P3EA shows 230 referring back to the engine, but p.2 has max. 285 hp continuous, 300 hp for takeoff.
