Hi All,
There's been plenty of tire talk on this site and others, but I'm hoping for some feedback specific to my situation. Any advice appreciated (including "quit dinking around with the small stuff, just go for the BW's!)
Equipment is a C170B with 145HP O-300A, 180 gear legs, 8042 climb prop, double-puck Cleavelands, Scott 3200 TW, and steel axles. No PPonk Beef Up Kit (yet).
Operating environment in summer is almost exclusively gravel, most of it maintained, some not. (Winter is skis)
Mission is having fun and having a margin, not necessarily speed.
Question at hand is whether to swap out existing McCreary 8:50x6 tires for a pair of 26" Goodyears. Both sets were/are free from friends. Both are in good condition.
One advantage in the Goodyears I think would be the smooth tire surface not grabbing and flinging rocks like the grooved McCreary's can do. A little more nose height above the gravel might extend the life of the prop too. Not sure how much of a diameter or footprint increase it really comes out to.
On the downside, weight and drag, obviously. Maybe different ground handling?
Some specific questions are:
What kind of paperwork would it require?
If the Goodyears need tubes, are the tubes from the McCreary's likely to work in them?
Do folks concur with the pros and cons listed above?
Anybody know what the increase in weight would be?
Any significant effect on vis over the glareshield during taxi?
Thanks a lot for any feedback,
-DenaliPilot
