hotrod180 wrote:mtv wrote: Drag anti drag wires are itty bitty parts. Look at the Spars, and Compare them to a Cessna spar. Those are PARTS.
Enough itty bitty parts and the weight adds up.
Since they're not needed for a metal-covered wing, that's why Maule apparently left them off.
Hence my comment about Maule wings being different than Pacer wings.
And BTW please remember we were talking about Maule wings vs Pacer wings, NOT Cessna wings.
You wanna look at a beefy spar, check out an RV6 spar, esp where it slides into the fuselage.
MTV is correct, all you need to look at beyond just the small details, they are very similar in design. Just to clarify two points I was trying to make:
It’s the choice of the airfoil and how the CM moves along the delta of Alpha (AOA) and the choise of wing attach points and consequently the spar location that dictate the dual strut.
The Maule and the Pacer wings are built on the same principle, so very similar, hence my point befor that you could mostly take a maule wing and cover it...
Mostly is a simple meas of sales yes but.... and in this case the but is anti drag wires, which considering that that all weighs could mean very similar weight vs a pacer wing. Now on a super cub, Piper original wings weigh ready to put on the strut 85-90lbs with paint.... what does a Maule wing weight? Btw that is a question not and affirmation... btw, since I do not know all the details of the maule wing, it could be that there is some stress in the skin/rib tomcount drag. If the ribs are thick enough, they might do the trick... “might.”
@MTV the issues with Randy’s design for the outbound was airfoil and spar type/locations. He was looking at ease of build and weight hence adding the truss between the spars to add a single strut. This meas as he build the arm out with a longer wing, then this moments on the truss increase substantially and minimizes the return on the original design concept.... it’s not necessarily a trade off but more of cause and effect scenario, faster plane single struted and higher wing loading or lower wing loading and slower plane because of dual struts.....
I have a Cessna wing for a 180, it weight in at 105lbs with paint read to go... so not that much of a difference. The build it spar is not necessarily heavier, Cessna might have design the wings in a way to leverage production (guessing here) and they might been able to interchange with different types and optimized for the heavier airplanes, thus a little heavier for the lowest on the scale. Bad? To you and I might sound bad, but if you have a single spar production line, it makes great business sense...optimization is a function of the variable you are trying to optimize.... $$$$
As for the RV.... you’ve lost me there, it’s important to understand that struted wing and counter lever wings have two different design concepts, and if you don’t have a substantially stronger attrach point vs a strutted wing, you will be... well let’s say VanGrunsven would not have been so successful.
Interesting enough, adding a truss at the strut attach point of the Piper or Maule wings and been able to move back your main strut, you could balance the forces to have a single strut, provided the strut was a to handle all the loads in the flight envelop. So adding 5-10lbs to you airplane could get you another ~10mph.
