Mile High
Discuss your knowledge of airports and off-airport strips. Help inform other pilots of status, warnings, noise abatement, and closure endangerment. See also:
http://www.shortfield.com
Has anyone flown in to mile high with a tricycle gear aircraft?
side slip offline
61
side slip wrote:Has anyone flown in to mile high with a tricycle gear aircraft?
Peterson(260SE?) Katiana -with Sparky Imeson driving .
182 STOL driver offline
1529
182 STOL driver wrote:side slip wrote:Has anyone flown in to mile high with a tricycle gear aircraft?
Peterson(260SE?) Katiana -with Sparky Imeson driving . May take 182 this year -got a video of 185 and 170's .
1529
Ah yes, I remember now that they landed the wren(katmai) there for the demo video. I've seen vids/pics of 185, 170 etc. there but couldn't remember seeing a trike. I would think that a good 182, or even a 180hp+ 172 should be fine in the proper conditions.
side slip offline
61
There has been at least one stock straight tail 172 into Mile High. Possibly two. May have been the same 172 with two different female pilots. I Have seen the photo of one of them.
Trimtab
Trimtab offline
170
Trimtab
It can be true, even if it didn't happen - Ken Keasey - mostly*
Man invented language so he could hide the truth from others - Tallyrand - sort of
Mile High airstrip is primarily limited by pilot ability and currency, not really by aircraft type. It is very short, steep, very challenging, hazardous, a little rough, and not very forgiving of any mistakes. Other than that it is great for many types of aircraft. See "Idaho August 2008 Trip 19" on You Tube. It is a Franklin 220hp Cessna 175 Tri gear at Mile High.
Lawleraero offline
47
Sun Jul 05, 2009 12:17 pm
The local outfitters have been taking Cessna 206's loaded with hunters, gear, elk meat, etc. in and out of Mile Hi, Vines and Dewey Moore for as long as I've been aware.
Matt 7GCBC offline
330
- FindMeSpot URL: http://share.findmespot.com/shared/face ... vXLMMuZOv7
If you have a capable plane and are good at touching down where you intend to, and are comfy on moderate slopes, then these are easy places to land and take-off from. If you don't then they would all be easy places to have some real problems.
taildrgfun offline
139
yup, seen the same photo of the 172 at mile high, and everywhere else u can name...pro lady pilots rock...
jomac offline
720
jomac
