Backcountry Pilot • Minor repairs on composite props (MT, Trailblazer, etc.)
34 posts • Page 2 of 2 • 1, 2
Re: Minor repairs on composite props (MT, Trailblazer, etc.)
I have about 500 hours on two MT propellers. One is a 2-blade on the Husky and one is a 3-blade on the 185. So far, I have not made any significant repairs to the blades. The leading edges look brand new. I did have a small ding in the steel leading edge of my husky prop before I had nickel leading edges added during an overhaul.
This in contrast to my two aluminum propellers that I ran prior to the MT props. They had dings in the leading edges that I couldn't get out completely and the filed leading edges looked bad.
The documents that came with my MT prop included a manual for repairs. I looked on the website but cannot find it there. I'm surprised no one has posted a copy of this manual because it shows how much damage can be repaired and it's surprising how much you can repair these props. Some of the photos show chunks way larger than I would feel comfortable having my mechanic deal with. The bottom line is that these blades can go a long way and can be repaired significantly.
I'm not sure I agree with "you either love or hate these props". Why so polarized? ..... But so far I love my props :)
Squash offline
My experience with MT’s, take it for what its worth.
180hp Supercub on 31s summer and wheel skis winter 2-blade MT. Good – fast cruise, smooth running. Bad – one rock ding from taxying on maintained gravel runway meant replacement of blade and downtime. It was a bad ding. Takeoff and climb performance nothing special, but not terrible either.
180hp Scout on floats 2-blade MT. Good – smooth, no unrepairable water erosion. Bad – water erosion ate paint off leading edge behind stainless steel. Not a big deal but looked bad and required upkeep to make sure the composite wasn’t becoming compromised. Takeoff and climb performance not impressive, but a lot of that is from big draggy floats.
285hp 180 on bushwheels, 2-blade MT. Good – smooth operation, fast cruise, lightweight. Bad – takeoff performance fine but nothing special. One rock ding from gravel bar smashed stainless steel leading edge in. Factory says its ok and owner still flying it so I guess its ok, just looks bad with a big ol bulge in leading edge.
300hp 185 on floats 3-blade MT. Good – lightweight for 3 blade, smooth running, good takeoff performance, no water erosion on second prop. Bad – first prop had bad water erosion behind ss leading edge within 100hrs. chipped paint and composite to the point was worried about moisture getting into the core. It was completely repairable, but when the trailing edge started to separate we traded it in for a new nickel leading edge prop. This one has held up great so far (1 year, 300ish hrs). Neither good nor bad – thoughts on performance: this prop replaced a 2-bladed 86in Mac that was recently OH but shook pretty good. The change to the MT made a HUGE difference in vibration, now its butter smooth. Takeoff performance is a bit better off the water, especially with a load. I do not feel it pulls quite as hard as the 3-blade Black Mac, but this is purely speculative as I have not done back to back tests. But after flying a bunch of different float planes you do develop a sense of it. FWIW
I have considered trying an MT on my pet wheel 180 with 275hp Pponk. The reason I haven’t yet is the lack of gain for $10k additional. The two-blade 86in Mac is smooth on this plane, relatively lightweight, and will pull any load I can land with out of the same spot so performance is good. Additionally, as a commercial plane the risk of having down time due to rock damage is too high. The MT with the nickel edge MIGHT handle it just fine. But I already know the Mac does. But the 3 blade MT would look so much cooler……
North River offline
Rob pointed out that one should be aware of the consequences of a catastrophic incident with a prop. Good advice.
But, as Rob pointed out for other aspects, there are actually two very different issues here as well.
I've seen that catastrophic damage of an MT prop.....upside down plane. And, no I wasn't flying it that day. Prop was toothpicks.....all used up. And that required a ride to town, but in that case, a metal prop wouldn't have been flyable either. So the ride to town would be required regardless of prop type....probably.
But, bear in mind that ANY prop strike requires an engine tear down. The engine on that plane passed with flying colors, and ran to tbo. Would a metal prop have inflicted more damage in the same circumstances? Probably, but how much? Would you rather have to pay for a ride to town or for a new crankshaft?
Finally, I know of a cub once that shed part of a blade. Shook like a dog shitting peach pits, but got on the ground ok. Called for a new prop, delivered shortly and installed. Pilot flew the plane to town, and it was inspected. Both lower engine mounts were cracked through. The cowling was basically holding the engine on. Had that come unstuck........
So, sometimes waiting out there May in fact be your best option.
mtv wrote:Battson,
To (hopefully) return this thread to your specific question, before I purchased a composite prop, I did some research on that flavor of props.
One gent I spoke to was the Director of Maintenance of an air carrier that was operating Beech 1900 aircraft off gravel runways regularly. These aircraft were all equipped with composite props. And those props were driven by fairly powerful turbines. He said before they figured out that turning off the nose wheel power steering would reduce rock damage to the props, they experienced frequent rock chips to the face of the blades.
The "fix" they used was "application of Marine Tex or other high quality epoxy coating" to repair those dings. He said turning off the power steering reduced the frequency of rock dings, but they still got many. He said they'd been using this procedure for some time with no issues, and it was approved by yhe manufacturer (this was a 121 operator).
The idea was to reseal the chip so that moisture couldn't seep into the wood core of the prop. Sorry, but I can't recall the manufacturer of the prop....but it wasn't MT.
I've used epoxy material to reseal rock chips on composite props, and seems to work fine.
One of the significant advantages of composite props is that if you're operating on gravel or worse, sand, there is virtually no erosion or damage to leading edges, unlike aluminum props, where you're constantly filing off $$$$ worth of leading edge,till you have a toothpick left. The same goes for props used on seaplanes and ski planes, where leading edge erosion can be substantial. The composite props have a hard steel leading edge which absorbs those rock dings with minimal damage.
I have run several composite props in both recreational flying and commercial ops, and I love them, fwiw. Of course, I got them all for free, otherwise, I'd have hated them....... :^o
Thanks Mike,
Cheers for taking the time to write that up.
I hear you - it's not really possible to repair a metal prop - just to dress out the damage with a file to prevent it getting worse.
Good to hear that composite props are easy to repair in their and your collective experiences. That's the kind of feedback I need!
Adding a little glue is no big deal, the plane spends most of it's time in the hangar... lots of time for glue to dry. Also, the Hartzell prop is 100% carbon fibre, so no wooden core to worry about.
fiftynineSC wrote:Things are rarely binary. Composite props have been "the standard" in other types of flying for years now. No reason they have to be "good" or "bad" in our application......everything has trade offs. I've seen the repairs on MT props (no experience with trail blazers) and they don't seem to be an issue. Very conventional materials and long history in other industries fixing minor blemishes in epoxy. My mechanic maintains several and he has no fears or qualms about them.
Making the argument about rocks and abrasion is one thing (surely debatable)...but saying or making the argument as some have made in other threads/forums that "they won't work" on our planes is just wrong. Go to an aerobatic competition on a weekend; they are hanging on the front end of 540's spinning at 2800 RPM exposed to radical gyroscopic forces every day. If it was a major problem they'd be grounded or their would at least be an AD. Composite props dominate that market.
59SC
Thanks 59SC - cheers for your feedback!
I agree - they seem to be getting more and more popular in our field.
AK-HUNT wrote:
Battson wrote:Hi everyone,
We find ourselves upgrading propellers, a nice position to be in! We are considering moving to composite instead of the ol' Black Mac.
We're sticking with a long two bladed prop, probably an MT or Hartzell Trailblazer.
A question about composite props - how easy are they to repair when minor stone chips appear in the aft face of the blades?
We had quite a bit of gravel rash on our old McCauley, on the aft face of the blades.
I wondered how the MT or Trailblazer will hold up to this kind of wear and tear?
All opinions and thoughts are encouraged! I want to hear those bad experiences as well as the good.
Battson
When I was on the verge of buying an MT, a local shop had one removed < 50 hrs having to go back to MT for a rock ding in the face. That was enough for me to stay with the Mac. A couple days not operating during my busy season would be a killer. There have been several other smoked MT's around here (theres a thread with pictures on the sky wagon Facebook....well there WAS anyway).
A local operation that runs one on their float plane seem to love it. If I were primarily on floats I'd do it or if the off-road stuff was a little tamer.
Weight/thrust/etc is honestly secondary to reliability for me....and most guys don't have huge repercussions by being grounded for a day or 2.
All this stuff is just tools. One tire/prop/rear seat/etc etc etc isn't "the best" for all operations IMO. Use whats best for you, but if you are getting mid cord dings, ya might look closely at the repair criteria. Could have changed. It doesn't help that when someone does bring up negatives of an MT they kinda get dogpiled. Makes it a polarizing issue (as u see above) and that doesn't help anyone.
Cheers,
KA
Thanks AK.
I hear what you are saying, and friends of mine flying commercial are saying the same. Being grounded for days or weeks with an unserviceable composite prop due stone damage is unacceptable.
For some of us private ops guys, maybe that issue isn't such a big deal, and composite might be a better fit?
Barnstormer wrote:Jon,
I have a Whrilwind on the SQ2. You've seen my videos so know what I flown on and off. When I was in Texas I could only fly off fine grain beach type sand with just a couple of times on the type of shale like what's at Skalywag's place. The prop was in pristine condition when I fly up here to Alaska. Nearly 300 hours last year in the aforementioned places you've seen in the videos. By seasons end there were hundreds of chips on the back side of the blades. Two on the front one of which was to the weave. I epoxied those two. I sent the blades back to Whirlwind for complete reconditioning/repainting at the cost of just over a grand (I was more concerned about some spider cracks in the "gel coat" near the root of the blades that ended up being just cosmetic).
I have no idea how a metal blade would have held up. I figure this is just the cost of doing the flying I do. BTW the prop has a nickel leading edge, I'm told far superior to a steel leading edge.
Thanks for sharing that Phil - that is precisely the kind of experience I wanted to hear about! Good man.
I guess the main different is, to Mike's point, that you CAN recondition your prop, either DIY or send it back to the shop. Good to have choice!
Whereas with a metal prop, when you lose metal it's never coming back. Of course the thick black paint on Mac's holds off the stones for a few dozen hours or so - but eventually you're losing 1/32nd of an inch at a time when big stones jump up.
PAMR MX wrote:The performance is great on the couple I'm around but that's it imo.
Minor face damage is extremely easy to repair. I simple dab of over the counter 5 min epoxy is all that is recommended. It can then be sanded smooth and painted. Deeper damage can be repaired as well and is fairly simple.
1. The whole prop has a coating of bondo that will develop cracks over time and look ugly. Manufacturer says it's airworthy but it's ugly. Image
2. Minor blade strikes that could be filed out and flown home on a metal prop destroy the mt. When a composite structure fails it fails catastrophically. Image
3. Minor dents in the leading edge all tho small in size and airworthy in size can delaminate the erosion sheath to an unairworthy amount.
4. I have had a rock completely penetrate the face of the prop to the other side.
5. They can be locally overhauled but the blades typically have to be shipped to Germany for repair. Exchange sets are available but not cheap.
Thanks MX - that is exactly the kind of operational experience I wanted to hear! =D>
motoadve wrote:I like the MT a lot, had mine for 1200hrs so far, 1 small nick, very easy to repair.
Epoxy, sand it and you are good to go.
Mine is on a 182 flying lots of backcountry, its durable in my opinion.
I do think they do give a real advantage for the backcoutry by being light, wide (its like an air brake) you also get quick throttle response .
Thanks guys - great to have the benefit of your experiences, this really helps. Cheers for posting.
The photos especially are great!
North River wrote:My experience with MT’s, take it for what its worth.
Squash wrote:I have about 500 hours on two MT propellers. One is a 2-blade on the Husky and one is a 3-blade on the 185. So far, I have not made any significant repairs to the blades. The leading edges look brand new. I did have a small ding in the steel leading edge of my husky prop before I had nickel leading edges added during an overhaul.
This is awesome. Thanks very, very much! =D> =D> =D>
I feel spoilt for information, a great way to be before a $20,000 decision...
Are either of you guys doing many operations off gravel, or mostly grass / water / seal?
Rob wrote:Hi Battson,
I still have not made the Chamois pursuit :?
Before I venture down a longwinded Rabbit hole, let me just put it out there, there are currently NO composite props that meet the criteria of your first post. No one, is currently making a Long, 2 bladed, constant speed, composite propellor for the big 6's. Craig Catto is making some dandy, long, fixed pitch, 4 cyl choices, but no one is currently making anything that will dethrone a 88"-90" C66 in the missions it shines in. And that propellor doesn’t work for you….
All of the props in your OP will take Superficial, Smooth stone chips just fine. The Aluminum props will just see dings, and lose paint or a touch of metal. The composite props will lose a touch of paint, and probably gain a couple little ugly epoxy patches which can be color matched if you feel so inclined.
Having said that I urge you to not make a purchase based on that single piece of knowledge. After all, buying a $10K-$20K propellor, is a substantial investment, (no matter what your bank account looks like) and more importantly, as Skaly and Slohawk note, a poor choice can leave your $200k bird ground bound, for extended stays.
Things I would urge you to evaluate would be;
1) First and as always, most importantly, Mission, mission, mission.... sounding like a broken record here, but as obvious as it is, if you elect to choose the softest tire on the market, you should have no gripes when it gets cut like soft butter with a hot knife, when it sees shale... choosing the lightest weighing prop can yield similar results. Will the mission need the weight loss more than the robustness? Some spell lightweight W-E-A-K.... in this application, I concur. (But two of my airplanes are still wearing a light weight props :wink: )
2) TBO's.... TBO's are like paychecks. Good bad or indifferent, It's how society has elected to judge a component's net worth. Electing to follow a TBO may a purely personal choice (for some), but as a general rule a component with a shorter TBO, has a shorter TBO for a reason, putting your head in the sand will not make that reason go away :wink:
3) Repair / service manuals.... A comprehensive, and open minded look in the manuals the most revered props on this website, will shed far more light that anyones opinion. There ways we simply must maintain these propellors. The books will tell you that information, the salesmen will not, the guy who really wants to believe his $20K investment is superior to others probably won't. In fact he probably hasn't gone down that rabbit hole himself :?
4) Customer service.... and not from the sales department! Selling $20K props has made them good at making you feel good. Poll the people who have had catastrophic failures, and how they were treated afterwards, because that relationship is likely to be far more important to your continued happiness with a product than the one that is forgotten shortly after you hand over your hard earned cash.
5) The BIG damage repairs. You wouldn't select a bush beater airplane solely on how well the grease wipes off the belly, don't pick a propellor sole on how it sheds superficial stone damage. Ask how it takes a stop sign, because it's the big damage that's going to leave you parked on a mountain side, not missing paint or dings. You are not buying a small disc'd prop meant to go on the nose of a lightweight acro buzzer, nearest I can tell for your mission, you are buying a giant weed wacker / stickball bat.
Anyways.. these are just some thoughts regarding props in general that anyone should consider. As luck would have it, I also have a bit of Mac (dozens) and MT (only 3) experience, some good, some bad (with both flavors). I can share some of that experience on another post, this afternoon. Skaly's initial post and MT experience does not surprise me in the least bit, nor does G44's. I know people that love them, I know people that hate them. All the reasons above and a few more (not another posters opinion) will determine which category you fall in. For my money MT’s in specific are just like any other prop out there, full of compromises... and merits
Take care, Rob
I've save the big one for last - and you've just about missed this year's Chamois rut! Next year then... do give me a call, I'll make it all happen. We can even fly in, fixed wing.
Rob - thanks for taking the time. Sounds like you've gone both metal and composite from time to tim.
Some details -
The mission, maximum thrust out of a hole, maximum cruise thrust, maximum drag at idle, maximum ramp appeal :)
I'll read the manual.
We're favoring the Trailblazer, so TBOs are the same as our Mac.
Customer service, and major boo-boos... We don't get any factory-direct support down here on the bottom of the world, so a major repair with any prop is a big deal. I can fix the minor stuff, and the rest is the rest.
Question then, if you were selecting a new prop for your bush plane - what would you choose and why?
Hartzell is marketing this new Trailblazer directly as us, the backcountry crowd. They offer is in an 83" model for a big 6 cyl. Not as long as I would like, but it's a very wide prop. They have tested it on a Bearhawk with the -540, and it shaved the take-off distance from 250ft down to about 150 feet. That is a serious improvement. Landing was also shorter, more drag and less weight.
On the IVO prop the recommended repair for chips is to use a mix of CrazyGlue and baking soda. It works great. The Bearhawk has the 4blade prop and does serious off-road stuff and has never had any serious problems.
175 magnum offline
175 magnum wrote:On the IVO prop the recommended repair for chips is to use a mix of CrazyGlue and baking soda. It works great. The Bearhawk has the 4blade prop and does serious off-road stuff and has never had any serious problems.
Nice, thanks.
More and more data coming together here.
For the most part, it sounds like composite props do OK on gravel provided they are operated carefully. Some will have bad luck and others good.
Baking soda....?! haha, wow.
My MT also has a few nicks and when purchased no maintenence manual came with the install instructions. Called today and had immediate response from customer service.
MT-Propeller USA, Inc.
1180 Airport Terminal Drive
DeLand, FL 32724, USA
Phone: (386) 736-7762
[email protected]
BEKE IN THE AIR offline
Aircraft: Cessna T182T
Wow
Thanks for the information!
I don’t have the money to put composite on my 185 anyways, but this kinda makes me think these are best for pavement based planes, or non working competition STOL planes, shame the weight reduction and looks are very attractive
Kinda suspected as much based on the plane that I came across with composite props vs the ones with metal, seemed more of working piston planes and old timers bush planes had metal and the private owned, especially rich guy or sponsored types, had composite
