http://www.greenskyadventures.com/bing/ ... etails.htm
Here is some proof that it works
Behind the panel hooked up to the HAC controller. It's basically just a metering valve.
Looking at the carbs. The clear line is the new stuff.
The short line that connects the two inner float bowl vents as part of the static system.
Before leaning
EGT's just over a 1000 and fuel flow 4.9 GPH. With this engines EGT redline is 1200 and they really like to run at around 1150.
Same conditions after leaning EGT's 1150 and fuel flow 4.1gph
Overall panel shot.. 4.1 gph at 78 mph IAS and 5850rpm. On my Idaho trip I was burning 5.3gph at these same power settings and altitudes.
Pulled back the power and got it down to 3.6 gph. I was indicating 72mph IAS at this power setting. I've NEVER seen fuel flow's below 4.0 gph above 5,000 rpm EVER.
For $159 I only need to fly about 30 hours for this thing to pay for itself. Fuel costs is only one benefit..... more power and less carbon build up are a few others.
