Backcountry Pilot • MMO, How Much?
MMO, How Much?
6 postsPage 1 of 1
MMO, How Much?
I have been running auto fuel in my 150 and it was suggested to me to run MMO. I have been trying to keep some Avgas in there too so there is some lead to lubricate the valves but sometimes I just have Mogas. How much do you use? I had a guy that rebuilds cylinders tell me he uses a shot glass in each tank on a 120. How big are the tanks on a 120 about 12 gallons? Thanks
Jaerl offline
Re: MMO, How Much?
I use 4oz's per 10 gallons, not sure why but it works great and I notice a difference.
Anyone else?
Re: MMO, How Much?
I used it all the time back when I had a C-180. Then one time I filled a glass gallon jug with non-ethanol 87 auto gas and the proper amount of MMO. I mixed it well and left it sit for 7-10 days. All the MMO settled out into a glob on the bottom. That was it with MMO for me.
Re: MMO, How Much?
I have used MMO ever since lead fouling of the bottom plugs in my Cont C-145 in the C-170 about 14 years ago. I contacted the Superior Engine people when I first got my ACA High Country and they said it was OK to run it in my O-360. As MM stated use 4 oz/10 gal of gas. When it is above 50F I just dump it in the tanks prior to filling. Below 50F I mix it 50/50 in a container with gas, shake it well, and then put in tanks prior to fueling. I run no more than 50% 91 Oct unleaded car gas with 100LL and have never had a problem. We changed out the cylinders at 100 hrs on the Superior O-360 because of a factory recall and when we checked all of the valve stems had a very fine coating of oil and the valves showed absolutely no wear.
I have never had a fouled plug up to 100 hrs since I started using MMO. Before MMO use, at 20 hrs on the C-145 Cont, I had new plugs fail. Almost everyone I know with a Continental engine uses MMO for the same reason.
Re: MMO, How Much?
4oz/10 gal, shaken not stirred. :D
I had heard of it settling out also So I mixed up some in a glass container to see what happned, and it stayed in suspension. :? Go figure. Guess that's why they call it mystery oil :D
I'll try it again.
As HiC says, it does seem to put a coating on all parts it comes in contact with, which hopefully helps protect them. I don't generally keep my tanks full, so I have also been hopin that the residual coating would help preserve the fuel bladders.
I put the MMO in the tank then add the gas, mixing it up. Never showed any concentration of MMO when sumping.
shortfielder offline
Re: MMO, How Much?
Jaerl wrote:How big are the tanks on a 120 about 12 gallons?
Pretty much, 12.5 gallons to be exact.
6 postsPage 1 of 1
