Backcountry Pilot • Montana Pilots Assoc License Plate Program
2 posts • Page 1 of 1
If you have a vehicle licensed in Montana the Montana Pilots Assoc would like you to consider getting the MPA's license plate. This plate costs you an extra $20 a year. That $20 goes to the two MPA scholarships that are given out each year at the state aviation conference.
The MPA plate is in danger of getting eliminated by the state unless we get to 400 plates in circulation. We're about 150 short so we need your help. There are two ways to do this. One is that you go down to your local DMV office and ask for the Montana Pilots Assoc Air Safety and Education plate. The second is to send either myself or Mike Vivion(MTV on this list and current MPA President) a copy of your car registration and $20. We have a deal worked out with the Bozeman DMV and they will handle any plate requests we bring in. Your plates will then be mailed to you.
It does not matter when your yearly registration expires, you can change your plate at any time. This will also not change or pay for that registration, you will do that at the normal time.
Scott Newpower
Past President-MPA
Bonanza Man offline
Re: Montana Pilots Assoc License Plate Program
Scott , IM sent .
umwminer offline
Aircraft: Citabria 7gcbc ,
