180Marty wrote:Occasional use is probably OK
Is a little over three years considered occasional?
In my opinion, yes- of it's on a once in a while basis. Re-reading your ealier post, you said after over 2 years of using E10 the carb shop thought your carb looked "very good" inside. Great. What about the rest of the fuel system, like your rubber fuel bladders & aluminum lines? I'd actually be more worried about the ethanol/water thing and the possibility of increased carb icing and water-slugging the carb.
Here's a couple mogas STC supplier webpages addressing ethanolized gas:
http://autofuelstc.com/autofuelstc/pa/ethanol.html www.eaa.org/autofuel/faqs/ethanol_blends.pdf I see you're in the corn belt, Marty, and as I recall you're involved in the corn-growing/ethanol industry? No offense, not trying to cause a fight, but IMHO you've got a vested interest in believing it's OK to use E10 in airplanes. I don't, and I don't-- esp after reading these two webpages by the outfits who've done the R&D work on mogas use.
To each their own, you burn what you like--I'll pass on E10 as long as E-zero is available in my area.
Eric
