http://www.cnn.com/2010/US/11/22/dc.airspace.violated/index.html?hpt=T2
Backcountry shortfield ops are for weenies....skirting the ADIZ is for the real brave souls.
They are all over the place now.GumpAir wrote:This shit's why I GLADLY pay the $30 a month for the XM Weather on my Garmin. Can't tell ya the number of times some TFR has popped up in the middle of nowhere out here in the vast desert wastelands. Like I'm gonna call FSS every time I want to hop in and go for a quick ride from dirt to dirt...They are all over the place now.
And with the VIP stuff, most of the presidential TFR's I've seen out here the XM will show the ring about 24 hours in advance. Lots and lots of head's up time.
kevbert wrote:I don't see how the student pilot could have done this. It was all in the TFR in plain english.![]()
Text of TFR 0/9477:
!FDC 0/9477 ZDC US.. FLIGHT RESTRICTIONS. WASHINGTON DC, US. . THIS NOTAM
REPLACES NOTAM 9/4399 DUE TO A CHANGE IN RESTRICTIONS PURSUANT TO 49 USC
40103(B), THE FEDERAL AVIATION ADMINISTRATION (FAA) CLASSIFIES THE AIRSPACE
DEFINED IN THIS NOTAM AS 'NATIONAL DEFENSE AIRSPACE'. PILOTS WHO DO NOT ADHERE
TO THE FOLLOWING PROCEDURES MAY BE INTERCEPTED, DETAINED AND INTERVIEWED BY LAW
ENFORCEMENT/SECURITY PERSONNEL. ANY OF THE FOLLOWING ADDITIONAL ACTIONS MAY ALSO
BE TAKEN AGAINST A PILOT WHO DOES NOT COMPLY WITH THE REQUIREMENTS OR ANY
SPECIAL INSTRUCTIONS OR PROCEDURES ANNOUNCED IN THIS NOTAM: A) THE FAA MAY TAKE
ADMINISTRATIVE ACTION, INCLUDING IMPOSING CIVIL PENALTIES AND THE SUSPENSION OR
REVOCATION OF AIRMEN CERTIFICATES; OR B) THE UNITED STATES GOVERNMENT MAY
PURSUE CRIMINAL CHARGES, INCLUDING CHARGES UNDER TITLE 49 OF THE UNITED STATES
CODE, SECTION 46307; OR C) THE UNITED STATES GOVERNMENT MAY USE DEADLY FORCE
AGAINST THE AIRBORNE AIRCRAFT, IF IT IS DETERMINED THAT THE AIRCRAFT POSES AN
IMMINENT SECURITY THREAT. PURSUANT TO TITLE 14 CFR SECTION 99.7, SPECIAL
SECURITY INSTRUCTIONS, ALL AIRCRAFT FLIGHT OPERATIONS ARE PROHIBITED WITHIN A 30
NMR OF 385134N/0770211W OR THE DCA VOR/DME UP TO BUT NOT INCLUDING 18000 FT MSL
EFFECTIVE 1009010401 UTC UNTIL FURTHER NOTICE. WITHIN AN AREA BOUNDED BY THE
FOLLOWING COORDINATES: 390145N/0773822W OR THE ARMEL /AML/ VORTAC 313 DEGREE
RADIAL AT 9.9 NM THEN CLOCKWISE ON A 30 NM ARC CENTERED ON 385134N/0770211W TO
391242N/0772930W OR THE ARMEL /AML/ VORTAC 004 DEGREE RADIAL AT 16.6 NM TO
390304N/0772838W OR THE ARMEL /AML/ VORTAC 004 DEGREE RADIAL AT 7 NM THEN
COUNTERCLOCKWISE ON A 7 NM ARC CENTERED ON 385605N/0772800W TO 390141N/0773324W
OR THE ARMEL /AML/ VORTAC 331 DEGREE RADIAL AT 7 NM TO THE POINT OF BEGINNING UP
TO BUT NOT INCLUDING 18000 FT MSL EFFECTIVE 1009010401 UTC UNTIL FURTHER NOTICE.
WITHIN AN AREA BOUNDED BY THE FOLLOWING COORDINATES: 385931N/0771830W OR THE
ARMEL /AML/ VORTAC 073 DEGREE RADIAL AT 8.2 NM THEN CLOCKWISE ON A 15 NM ARC
CENTERED ON 385134N/0770211W TO 390628N/0770432W OR THE WASHINGTON /DCA/ VOR/DME
002 DEGREE RADIAL AT 15 NM TO 390218N/0765038W OR THE BALTIMORE /BAL/ VORTAC 238
DEGREE RADIAL AT 11.7 NM TO 385901N/0764832W OR THE ANDREWS /ADW/ VORTAC 024
DEGREE RADIAL AT 10.9 NM THEN CLOCKWISE ON A 13 NM ARC CENTERED ON
385134N/0770211W TO 385052N/0771848W OR THE ARMEL /AML/ VORTAC 134 DEGREE RADIAL
AT 8.9 NM TO THE POINT OF BEGINNING UP TO BUT NOT INCLUDING 18000 FT MSL;
EXCLUDING A 1 NMR OF 385629N/0764621W OR THE ADW039009.2 UP TO BUT NOT INCLUDING
18000 FT MSL EFFECTIVE 1009010401 UTC UNTIL FURTHER NOTICE. THIS NOTAM AND A
NOTAM FOR THE LEESBURG MANEUVERING AREA SUPPLEMENT SUBPART V, 14 CFR PART 93 FOR
THE WASHINGTON, D.C. SPECIAL FLIGHT RULES AREA (DC SFRA). PURSUANT TO 49 USC
40103(B), THE FAA HAS ESTABLISHED THE DC SFRA AREA AS 'NATIONAL DEFENSE
AIRSPACE. ANY PERSON WHO DOES NOT COMPLY WITH THE REQUIREMENTS APPLICABLE TO THE
DC SFRA MAY BE INTERCEPTED, DETAINED AND INTERVIEWED BY LAW ENFORCEMENT/SECURITY
PERSONNEL. ANY OF THE FOLLOWING ADDITIONAL ACTIONS MAY ALSO BE TAKEN AGAINST A
PILOT WHO DOES NOT COMPLY WITH THE REQUIREMENTS OR ANY SPECIAL INSTRUCTIONS OR
PROCEDURES ANNOUNCED IN THIS NOTAM: 1. THE FAA MAY TAKE ADMINISTRATIVE ACTION,
INCLUDING IMPOSING CIVIL PENALTIES AND THE SUSPENSION OR REVOCATION OF AIRMEN
CERTIFICATES; 2. THE UNITED STATES GOVERNMENT MAY PURSUE CRIMINAL CHARGES,
INCLUDING CHARGES UNDER TITLE 49 OF THE UNITED STATES CODE, SECTION 46307; 3.
THE UNITED STATES GOVERNMENT MAY USE DEADLY FORCE AGAINST THE AIRBORNE AIRCRAFT,
IF IT IS DETERMINED THAT THE AIRCRAFT POSES AN IMMINENT SECURITY THREAT. A.
THIS NOTICE SUPPLEMENTS THE DC SFRA WITH ADDITIONAL GUIDANCE AND INFORMATION. B.
APPLICATION OF DEFINITIONS IN SUBPART V, 14 CFR SECTION 93.335: 1. THE DC
FLIGHT RESTRICTED ZONE (DC FRZ) FLIGHT PLAN FULFILLS THE REQUIREMENT FOR A DC
SFRA FLIGHT PLAN. A DC FRZ FLIGHT PLAN MUST BE FILED WITH FLIGHT SERVICE AT
866-225-7410 begin_of_the_skype_highlighting 866-225-7410 end_of_the_skype_highlighting. THE INITIATOR/PILOT MUST IDENTIFY THEMSELF AND USE THE
CONFIDENTIAL PILOT IDENTIFICATION CODE OR THEIR WAIVER NUMBER. 2. A DC SFRA
FLIGHT PLAN DOES NOT FULFILL THE REQUIREMENTS FOR VISUAL FLIGHT RULES (VFR)
OPERATIONS IN THE DC FRZ. A DC FRZ FLIGHT PLAN IS REQUIRED FOR VFR OPERATIONS IN
THE DC FRZ. 3. PILOTS MAY NOT FILE A DC FRZ FLIGHT PLAN WHILE AIRBORNE. C.
ADDITIONS TO OPERATING IN THE DC SFRA 14 CFR SECTION 93.339: 1. AIRCRAFT
OPERATING IN THE DC SFRA MUST BE EQUIPPED WITH AN OPERABLE TWO WAY RADIO CAPABLE
OF COMMUNICATING WITH ATC ON APPROPRIATE RADIO FREQUENCIES OR UNICOM. IT IS
HIGHLY RECOMMENDED THAT A PILOT CONTINUOUSLY MONITOR VHF FREQUENCY 121.5 OR UHF
FREQUENCY 243.0 FOR EMERGENCY INSTRUCTIONS WHEN OPERATING AN AIRCRAFT IN THE DC
SFRA, EITHER IN AN AIRCRAFT THAT IS SUITABLY EQUIPPED, OR BY USE OF PORTABLE
EQUIPMENT. 2.ANY PERSON OPERATING AN AIRBORNE AIRCRAFT UNDER VFR WITHIN OR
TRANSITING THE DC SFRA/FRZ WHO IS AWARE OF AN INABILITY TO COMPLY WITH THE
REQUIREMENT TO MAINTAIN RADIO CONTACT WITH ATC MUST IMMEDIATELY SQUAWK 7600 AND
EXIT THE DC SFRA/FRZ BY THE MOST DIRECT LATERAL ROUTE UNLESS; 1) THE
DEPARTURE POINT IS WITHIN THE SFRA AND THE DEPARTURE POINT IS CLOSER THAN THE
SFRA BOUNDARY, THE PILOT MAY RETURN TO THE DEPARTURE POINT BY THE MOST DIRECT
ROUTE. 2) IF THE DEPARTURE POINT IS WITHIN THE FRZ AND THE AIRCRAFT IS
WITHIN 5 NM OF THE DEPARTURE POINT, THE PILOT MAY RETURN TO THE DEPARTURE POINT
BY THE MOST DIRECT ROUTE. OTHERWISE, THE PILOT MUST EXIT THE FRZ VIA THE MOST
DIRECT ROUTE. 3.ANY PERSON OPERATING AN AIRBORNE AIRCRAFT UNDER INSTRUMENT
FLIGHT RULES (IFR) WITHIN OR TRANSITING THE DC SFRA/FRZ WHO IS AWARE OF AN
INABILITY TO COMPLY WITH THE REQUIREMENT TO MAINTAIN RADIO CONTACT WITH ATC MUST
CONTINUE THE FLIGHT VIA THE TWO-WAY RADIO COMMUNICATIONS FAILURE PROCEDURES
FOUND IN THE FAA AERONAUTICAL INFORMATION MANUAL (AIM) OR APPLICABLE FEDERAL
AVIATION REGULATIONS (FAR). 4.AIRCRAFT DEPARTING AIRPORTS WITHIN THE SFRA WITH
LIMITED TWO-WAY RADIO COMMUNICATIONS MUST ESTABLISH TWO-WAY COMMUNICATIONS AS
SOON AS FEASIBLE, NORMALLY WITHIN 2NM OF THE DEPARTURE POINT. 5. . OPERATIONS IN
THE TRAFFIC PATTERN IN PARAGRAPH SECTION 93.339 (D) ARE LIMITED TO PRACTICE VFR
FLIGHT OPERATIONS WITHIN THE TRAFFIC PATTERN. D. ADDITIONS TO OPERATING IN THE
DC FRZ 14 CFR SECTION 93.341. ALL OPERATIONS ARE PROHIBITED WITHIN THE FRZ
(INCLUDING TRANSIT) UNLESS OUTLINED BELOW: 1. THE FOLLOWING OPERATIONS
ARE NOT AUTHORIZED WITHIN THE DC FRZ: FLIGHT TRAINING, AEROBATIC FLIGHT, GLIDER
OPERATIONS, PARACHUTE OPERATIONS, ULTRA LIGHT, HANG GLIDING, BALLOON OPERATIONS,
TETHERED BALLOONS, AGRICULTURE/CROP DUSTING, ANIMAL POPULATION CONTROL FLIGHT
OPERATIONS, BANNER TOWING OPERATIONS, MAINTENANCE TEST FLIGHTS, MODEL AIRCRAFT
OPERATIONS, MODEL ROCKETRY, FLOAT PLANE OPERATIONS, UNMANNED AIRCRAFT SYSTEMS
(UAS) AND AIRCRAFT/HELICOPTERS OPERATING FROM A SHIP OR PRIVATE/CORPORATE YACHT.
2. IT IS HIGHLY RECOMMENDED THAT A PILOT CONTINUOUSLY MONITOR VHF
FREQUENCY 121.5 OR UHF FREQUENCY 243.0 FOR EMERGENCY INSTRUCTIONS WHEN OPERATING
AN AIRCRAFT IN THE DC FRZ, EITHER IN AN AIRCRAFT THAT IS SUITABLY EQUIPPED, OR
BY USE OF PORTABLE EQUIPMENT 3. ALL AIR AMBULANCE FLIGHTS MUST OBTAIN AND
COMPLY WITH AN FAA/TSA WAIVER FOR OPERATIONS WITHIN THE FRZ. 4. ALL U.S.
STATE AND LOCAL LAW ENFORCEMENT AIRCRAFT MUST OBTAIN AND COMPLY WITH AN FAA/TSA
WAIVER FOR OPERATIONS WITHIN THE FRZ. 5. APPROVED DOD, LAW ENFORCEMENT,
AND LIFEGUARD/AIR AMBULANCE OPERATORS MAY CONDUCT TRAINING/MAINTENANCE FLIGHTS
WITHIN THE DC FRZ WITH PRIOR APPROVAL AND COORDINATION WITH THE TSA NCRCC AT
866-598-9520. THESE OPERATIONS ARE TO BE KEPT TO A MINIMUM CONSISTENT WITH
FLIGHT SAFETY AND PILOT PROFICIENCY. 6. THE FAA OFFICE OF SYSTEM OPERATIONS
SECURITY MAY EXEMPT OPERATORS FROM RESTRICTIONS BASED ON SAFETY, CRITICALITY AND
TIMELINESS OF THE MISSION REQUIREMENTS BEING PERFORMED. E. ADDITIONS TO
OPERATING IN THE DC FRZ 14 CFR SECTION 93.341, OPERATIONS AT RONALD REAGAN
WASHINGTON NATIONAL AIRPORT (DCA): 1. PART 121 AND 129 REGULARLY SCHEDULED AIR
CARRIER FLIGHTS WITH TSA APPROVED AIRCRAFT OPERATOR STANDARD SECURITY PROGRAM,
FULL ALL CARGO AIRCRAFT OPERATOR STANDARD SECURITY PROGRAM OR MODEL SECURITY
PROGRAM (MSP) AND HAVE SPECIFIC AUTHORIZATION FROM THE DEPARTMENT OF
TRANSPORTATION (DOT), MAY LAND AND DEPART RONALD REAGAN WASHINGTON NATIONAL
AIRPORT (DCA) HEREIN REFERRED TO AS DCA APPROVED CARRIERS 2. DCA APPROVED
AIR CARRIERS, OPERATING UNSCHEDULED, CHARTER OR ADDITIONAL SECTIONS MAY OPERATE
WITHOUT A WAIVER UNDER THE FOLLOWING CONDITIONS: 1) ALL OPERATIONS MUST BE
CONDUCTED IN ACCORDANCE WITH THEIR TSA AIRCRAFT OPERATORS STANDARD SECURITY
PROGRAM (AOSSP) AND MUST DEPART A TSA OR EQUIVALENT SCREENED TERMINAL GATE. 2)
THE TSA NCRCC MUST BE NOTIFIED BY TELEPHONE AT LEAST ONE HOUR PRIOR TO DEPARTURE
AT 866-598-9520. 3) UNSCHEDULED OPERATIONS AT DCA REQUIRE A SLOT
RESERVATION PER 14 CFR PART 93, SUBPART K. ADDITIONAL INFORMATION MAY BE
OBTAINED IN ADVISORY CIRCULAR (AC) 93-1. 3. ALL OTHER FLIGHTS MUST OBTAIN
AN FAA/TSA WAIVER OR DCA ACCESS STANDARD SECURITY PROGRAM (DASSP) SECURITY
AUTHORIZATION. ELIGIBLE OPERATIONS FOR A FAA/TSA WAIVER ARE LIMITED TO: U.S.
GOVERNMENT OPERATIONS (GOV), ELECTED OFFICIALS (ELO), SPECIAL OPERATIONS (SPO),
DOD, LAW ENFORCEMENT, AIR AMBULANCE FLIGHTS OR TSA AIRCRAFT OPERATORS STANDARD
SECURITY PROGRAM (AOSSP). UNSCHEDULED OPERATIONS AT DCA REQUIRE A SLOT
OBTAINED IN ADVISORY CIRCULAR (AC) 93-1. 4. DOD AND FEDERALLY OWNED AND
OPERATED AIRCRAFT ON AN OPERATIONAL MISSION, WITH PRIOR FAA APPROVAL, MAY LAND
AND DEPART DCA WITHOUT A WAIVER. APPROVAL FROM THE FAA NCRCC MUST BE OBTAINED AT
LEAST ONE HOUR PRIOR TO DEPARTURE VIA TELEPHONE AT 866-598-9522 . 5. DOD
AND FEDERALLY OWNED AND OPERATED AIRCRAFT ON A TRAINING OR FERRY FLIGHT MAY NOT
LAND OR DEPART DCA UNLESS THE OPERATOR HAS APPLIED AND RECEIVED AN FAA/TSA
WAIVER. 6. FOREIGN STATE OR DIPLOMATIC AIRCRAFT ARE NOT AUTHORIZED TO LAND
OR DEPART AT DCA. F.ADDITIONS TO OPERATING IN THE DC FRZ 14 CFR SECTION 93.341,
OPERATIONS AT ANDREWS AFB (ADW) AND DAVISON ARMY AIRFIELD (DAA): 1. DOD
OWNED AND OPERATED AIRCRAFT MAY OPERATE AT ADW OR DAA WITHOUT AN FAA/TSA WAIVER
AND ARE RESPONSIBLE FOR THE SECURITY OF THEIR AIRCRAFT, CREW AND PASSENGERS. 2.
FEDERALLY OWNED AND OPERATED AIRCRAFT MAY OPERATE AT ADW OR DAA WITHOUT AN
FAA/TSA WAIVER. THESE APPROVED GOVERNMENT OPERATORS ARE RESPONSIBLE FOR THE
SECURITY OF THEIR AIRCRAFT, CREW AND PASSENGERS AND ARE REQUIRED TO NOTIFY THE
FAA NCRCC ONE HOUR PRIOR TO DEPARTURE AT 866-598-9522. . 3. DCA APPROVED
CARRIERS, OPERATING UNSCHEDULED OR CHARTER FLIGHTS INTO ADW OR DAA, IN SUPPORT
OF U.S. GOVERNMENT OPERATIONS MAY OPERATE WITHOUT A WAIVER UNDER THE FOLLOWING
CONDITIONS: 1) ALL OPERATIONS MUST BE CONDUCTED IN ACCORDANCE WITH THEIR
TSA AIRCRAFT OPERATORS STANDARD SECURITY PROGRAM (AOSSP), INCLUDING DEPARTING
FROM A TSA OR EQUIVALENT SCREENED TERMINAL. 2) NOTIFICATION TO THE TSA
NCRCC VIA TELEPHONE AT 866-598-9520 IS REQUIRED AT LEAST ONE HOUR PRIOR TO
DEPARTURE. 4. AN FAA/TSA WAIVER IS REQUIRED FOR ALL STATE, LOCAL
GOVERNMENT AIRCRAFT, DOD CONTRACT (INCLUDING CONTRACT AIRCRAFT USING MILITARY
CALL SIGNS), ON DEMAND PASSENGER OR CARGO OPERATIONS INCLUDING ALL PART 121,
125, 129, 135 FLIGHTS LANDING AND DEPARTING ADW OR DAA NOT LISTED AS A DCA
APPROVED CARRIER. NOTIFICATION TO THE TSA NCRCC VIA TELEPHONE AT 866-598-9520 IS
REQUIRED AT LEAST ONE HOUR BEFORE DEPARTURE. 5. 14 CFR SECTION 93.341
(C)(4) STATES THAT PRIOR PERMISSION MAY BE REQUIRED TO LAND OR DEPART ANDREWS
AIR FORCE BASE, MD (ADW) OR DAVISON ARMY AIRFIELD (DAA). A PRIOR PERMISSION
REQUIRED (PPR) APPROVAL DOES NOT AUTHORIZE ENTRY INTO THE FRZ OR SUPERSEDE THE
REQUIREMENTS OF THIS NOTAM. 6. FOREIGN OPERATED MILITARY OR FOREIGN STATE
AIRCRAFT OPERATIONS WITH A U.S. STATE DEPARTMENT DIPLOMATIC CLEARANCE, AND A
PPR, MAY LAND AND DEPART ONLY AT ADW WITHIN THE DC FRZ. DAA IS NOT AUTHORIZED
FOR ARRIVAL OR DEPARTURE OF FOREIGN DIPLOMATIC FLIGHTS. G.IN SUBPART V, 14 CFR
SECTION 93.343 (A)(2) A DC SFRA FLIGHT PLAN WILL NOT FULFILL THE REQUIREMENTS OF
A DC FRZ FLIGHT PLAN. H.RESOURCES: 1. THE CODE OF FEDERAL REGULATIONS CAN BE
FOUND ON THE GOVERNMENT PRINTING OFFICE WEBSITE AT
HTTP://WWW.GPOACCESS.GOV/CFR/INDEX.HTML. 2. DIRECT ANY PILOT PROCEDURAL
QUESTIONS ON THE DC SFRA OR FRZ TO FAA SYSTEM OPERATIONS SECURITY AT 9-AWA-ATS-
[email protected]. 3. FOR THOSE WAIVERS AND SECTIONS THAT REQUIRE NOTIFICATION TO
THE TSA NCRCC CALL 866-598-9520. 4. FOR THOSE SECTIONS THAT REQUIRE NOTIFICATION
TO THE FAA NCRCC CALL 866-598-9522. 5. INFORMATION ABOUT WAIVER APPLICATIONS
AND TSA SECURITY AUTHORIZATIONS CAN BE FOUND AT
HTTP://WWW.TSA.GOV/WHAT_WE_DO/TSNM/GENE ... IVERS.SHTM (CASE
SENSITIVE USE LOWER CASE ONLY) OR BY CONTACTING TSA AT (571) 227-2071.
INDIVIDUALS MAY SUBMIT A REQUEST FOR A FAA WAIVER AT HTTPS://WAIVER.C3.FAA.GOV.
6. AFTER NORMAL BUSINESS HOURS, FOR EMERGENCY OR SHORT NOTICE REQUESTS, CONTACT
TSA NCRCC AT 866-598-9520. 7. FOR OPERATIONS IN THE DC FRZ PILOTS WITH A
WAIVER OR CONFIDENTIAL PILOT IDENTIFICATION CODE, MUST CALL FLIGHT SERVICE AT
866-225-7410 TO FILE A DC FRZ FLIGHT PLAN. 8. INFORMATION ON U.S. DIPLOMATIC
CLEARANCE AND LANDING AUTHORIZATION PROCEDURES CAN BE FOUND AT
HTTP://USEG.ORG/USEG.HTML. I.IT IS STRONGLY RECOMMENDED THAT ALL PILOTS FLYING
UNDER VISUAL FLIGHT RULES (VFR) WITHIN 100 NM OF THE DCA VOR/DME COMPLETE
SPECIAL AWARENESS TRAINING FOR THE WASHINGTON DC METROPOLITAN AREA, THIS
TRAINING IS MANDATORY FOR ALL PILOTS THAT FLY UNDER VFR WITHIN 60 NM OF THE DCA
VOR/DME (14 CFR PARTS 61 AND 91, EFFECTIVE FEBRUARY 9, 2009). THIS TRAINING IS
AVAILABLE IN THE AVIATION LEARNING CENTER AT HTTP://WWW.FAASAFETY.GOV.
BCP Newbie Guide wrote:9. Do not use all capital letters. In addition to all caps being annoying and difficult to read, they are the internet convention for YELLING! Save all caps for METARs, TAFs, and RAISING YOUR VOICE!!
