Backcountry Pilot • MT 3 Blade vs 86" 3 Blade McCauley TEST COMPLETED
43 postsPage 1 of 31, 2, 3
Here is the test-
MT MTV-9-D/210-58 3 blade composite propeller
VS
McCauley D3A3C401 86” 3 blade aluminum propeller
This is what MT has to say:
http://www.flight-resource.com/PTD/Cessna185.pdf
So it looks as though its going to happen middle of next week just looking at our weather. Obviously looking for zero wind. Field elevation is 4980'. I will try to get the K factor for sea level figures. We have a lot of folks looking to help as I know there will be some serious scrutiny.
My objective is to decide which prop is best for MY needs and mission.
My needs are:
The best prop that allows the greatest thrust for the shortest take off for my 180.
Best time to climb
Best time for a 1 mile distance at a given power setting.
Best weight on my nose
Best overall durability (this one will be hard)
Can you think of anything else you would like to see?
We finally opened the box today and out she came...
And a big thanks to John Neilson at Flight-Resources. He is letting me use their Strain Pull Gage. This tool is going to be fun.
So if you would like to be a part of the testing just let me know and I will keep you in the loop. Looks like Wednesday/Thursday of this next week will be our day.
I look forward to your feed back.
Thanks
AKT
Re: Here we go - MT 3 Blade vs 86" 3 Blade McCauley
Hot damn! My bet's on the MT.
Durability is going to be tough to test, as you really don't want to weather the damage just because.
Way cool.
No experience with either, but I can speak to prop damage. We ran 2 blade seaplane props on 180's and a 185 for years. Lots of off- road. The only time we injured one was when we were too lazy to take the 26 Goodyears off and put the 29" Bushwheels back on.
Even with minimal prop saving technique, the big tires will take care of you, which ever one you decide to keep.
If I were to make a bet on gut feeling alone, I'd wager the Mac will pull a tiny bit harder but you'll end up liking the MT better overall.
Thanks for sharing!
gb
gbflyer offline
woot - this should be good! I just picked up a 3 blade MT from John, looking forward to hearing how it does...
Vick offline
Solum Volamus
I run the 86" McCauley on my '79 185, and like it, but especially on floats alot of folks rave about the MT. I know there is a 55o in my future, based on your tests I might swap to an MT. Keep me posted!
-Brad
Durango Skywagon offline
My Spot Page
I think you will find that the Mac pulls a tad better (more thrust)
I think you will find that thrust alone will not always make for the shortest take offs because the MT will spool up quicker. (unless of course you are one of those that holds brakes and pours on the coal)
The next two items will be affected by wing and weight also, so I can't speak to your combination.
The weight question is a no-brainerd, but more important than the weight is how it affects your CG, and again I can't speak to yours. CG was the single biggest factor to me, but it's not for most people.
The durability question is not hard....The only thing the MT takes better than the Mac is water erosion. I can tell you two unfortunate pitfalls to the MT... The MT does not tolerate extremely arid environments well, and certain types of leading edge damage (damage that will appear minor) will require blade removal for repair.
Go easy on the power on shale, and be mindful of the sun if you live in a desert environment and neither of these should be a deal breaker...
I will be interested to see how you results compare...
Take care, Rob
Rob offline
My bet is the Mt.
It will be another interesting thread from the Truckee area
Sent from my iPad using Tapatalk HD
Juan80 offline
Chuck
Kevin, I recently replaced my 3 blade Mac with the MT. Mke sure you to do the dynamic balancing after installation. Although it was a new prop and I couldn't feel a difference afterward, my A&P told me it required a significant amount of balancing. The combination of the MT and Gami's make for a smooth running engine. Can't wait for the test results!
4Whitey offline
I look forward to your test. I have the same prop on my 520 and need a overhaul. Maybe I should consider a swap to the MT.
Are you switching for performance or you at overhaul or what?
73. 182 Amphibian with Aerocets
pilotjpw1 offline
Hi there, can't wait for your results - I am in decision for a new prop for my A185E, summer on amphibs 2790, winter on skis
Ed
skyede offline
keep me in the loop, Ed
skyede offline
Any news ?
bcdpilot offline
Monday as of now. The weather has just not been conducive to do such.
AKT
We finally completed this today...
I can tell you in short, the MT kicked the Mac's ass 10 ways to Sunday. It was not even close. Thats honest.
I dont have the time to report all numbers and info but will try and get back to this tonight if not in the AM for certain.
The MT out pulled the Mac by almost 100lbs at 2700rpm at 4900'. Heck, the MT out pulled the Mac when it cleared 2500rpm.
Stay tuned for photos and all specs. We gathered alot of information.
AKT
Re: MT 3 Blade vs 86" 3 Blade McCauley TEST COMPLETED
This does not help me, talking myself down from saving for an MT...
BRING ON THE DETAILED RESULTS!! =D> =D> [-o<
Holly shit now I have to buy an MT instead of the McCauley as soon as I get the $15,300
bcdpilot offline
You do realize you are going to cost a bunch of people here a bunch of money posting this stuff...
Luckily for me my bird is too rudimentary to be in line for an MT...
Troy Hamon offline
Aircraft: Piper PA-22
bcdpilot wrote:Holly shit now I have to buy an MT instead of the McCauley as soon as I get the $15,300
Jeez Billy, another week of sittin on your ass and you can pay cash for one......frickin corporate pilots. :D
Oh wait........maybe Obama will buy you one! :shock:
Hafast offline
Your just jealous :D and your right I am sitting on my ass away from home that MT would sure be nice though
bcdpilot offline
Hell I am poor as a church mouse I can dream though
bcdpilot offline
