Rhyppa wrote:I think any plane could benefit from less weight on the nose, got to be better for the crank, the mount, the airframe, everything. ...........
180Marty, I have the K engine as well and am curious about the MT prop. Please post a pirep when you've flown your new MT prop for a while.
Rhyppa wrote:I thought I would put in a report on my new MT propeller. My plane is a 1973 Cessna 182, PPONK motor, wing extensions, on Aerocet 3500 straight floats. It came with an 80 inch Mac 401 3 blade prop. I have flown about 70 hours last float season with this prop, and performance was good, however when VERY heavy and hot days, I could use a little water to get airborne. Float flyers here will understand VERY heavy. Anyway, I just got the plane out of annual with a new MT MTV -15-D/210-58 two blade prop, this is 83 inches (210cm). I played with it for about an hour yesterday. One word describes it -WOW! My seat of the pants feel for it is it gets on step in 1/2 the time, water run is 2/3 to 3/4 of what it was with the mac, and climb - incredible. I could hold 1500 fpm at 80 mph indicated at 25 squared, elevation was about 1000 asl, temp 68, wind 10-15mph. I was at about 2800 gross, not HEAVY, but not light. 1500 fpm in a float plane of this size at this weight is impressive. The prop is extremely quiet- and the guys on the ground commented on that first thing - and very smooth. It spins up to 2700 rpm instantly, I suppose because it is so much lighter. Top end speed I would also estimate to be a few mph faster. I was indicating 138 mph at 3000 feet, 22 squared. Also, that 40 pound weight savings on the nose of the plane is very noticeable. I used to run out of trim when landing with just me and full fuel, no longer and issue. Front of the floats also seem to be a little higher out of water due to weight savings - better for prop wear. I am looking forward to getting HEAVY and seeing what it does. Thus far, I am impressed. Russ
