Backcountry Pilot • Multiple weight and balance sheets for different configs
95 posts • Page 1 of 5 • 1, 2, 3, 4, 5
AntiCub wrote:Before spending money on mods, make sure you're getting the most out of your current plane.
I thought I was pretty skilled with my stock C-150, but I picked up a copy of "The Mountain Flying Bible - Revised" last winter. It's the only book I've found that really details short and soft field technique for trikes, with modifications for low powered aircraft. Using the techniques described there I've cut a good 30% off my takes offs from grass/dirt strips. Since the 150 will stop in about 1/2 the Take-off distance that's really significant.
Next I'd say make sure your plane is as light as possible. Remove any dead or obsolete avionics or abandon wiring. Remove or substitute lighter cabin interior components. Old damp fiberglass sound proofing can add up to a lot of weight, not to mention the corrosion concerns. How often do you need the back seat? Take it out if you can. How about one of the new lightweight batteries and starters?
One tire size up can help too, especially with low powered planes like my 150. It had 5.00x5 mains when I got it, just going to 6.00x6 made a huge difference on grass and dirt strips. But I suspect there's a point of diminishing return here, 31" bushwheels probably lengthen take off from smooth fields due to the extra weight and rolling resistance. Also, check you tire pressures, I notice the extra drag taxiing if my tires are only 3 or 4 psi low. Soft tires only help on really soft ground, on frim ground they add resistance.
I'm no bush pilot by any stretch, these are some little things I've found that have helped me get my 150 in and out with more of a safty margin.
Phil
If you take the back seat out make sure you have a new weight and balance in the plane for no rear seat. If not and you get ramp checked you may be stuck where you are. :roll:
iceman offline
Jr.CubBuilder wrote:You should be able to calculate the weight & balance. The rear seat station is in the TCDs, weight it, calculate the arm and you have your new CG. You shouldn't have to take the plane in to be weighed on scales again just because you took the rear seat out. I assume that's what you ment.
I was in this situation too. It's not a matter of just having an accurately W&B for any given flight, it's a legality. Since the rear seat is considered a permanent part of the aircraft (bolted in), if it's removed, a new calculated weight and balance reflecting that needs to be in the aircraft in order to fly legally. You can carry more than one W&B sheet for your various configurations, as long as they're signed by an IA...or do you just need an A&P?
This was explained to me by an instructor who did a lot of skydiver hauling and was always removing and replacing seats, doors, etc.
trust me you need a new weight and balance done by a a&p not necessarily an AI. Just calculating the W&B isn't enough. Good call Zane. My A&P advised me of this as did my old flight instructor. A&P just did one for me and I keep it in the plane. =D>
iceman offline
I think I have seven or eight W & B in my airplane, all CALCULATED by an A & P. You only have to weigh it once, and the mechanic can extrapolate from that, but YOU don't get to do that deed, as Zane noted.
If, for example, you run retractable wheel skis, as I do, you have to have a W & B for skis up AND skis down, since the skis move forward and aft in this process. Same for certain amphibs.
So, seat in, skis down. Seat out, skis down, seat in skis up,
Etc,
MTV,
I'm an A&P/IA and retired military, so I confuse regulations all of the time, but it takes an A&P to do a weight and balance? Can't the pilot do as many weight and balance calculations as they want and aren't these legal?
I mean anybody can do simple math, Weight x Arm = Moment or WAM is all you need to know.
a64pilot offline
a64pilot wrote:MTV,
I beleive MTV is correct. An A&P needs to sign the weight and balance sheets. What I have done is to do my W&B on the computer for the various combinations that could conceivably be configured...take that to my mechanic and have him review and sign it. My current sheet has floats, wheels and skis with and without the back seat in.
Speaking of the back seat, I also beleive a mechanic needs to give a pilot a signed "permission slip" to remove and reinstall the back seat. I don't have this yet but will work on getting that soon.
So, the FAA beleives that mechanics are more able to do the complicated W&B sheets than pilots are, and that pilots need to be shown the correct way to remove two 1/4" bolts holding the back seat in...after all, that "righty-tighty--lefty-loosey" thing can get pretty confusing sometimes :D
Actually, I think for some planes, instruction on removing the seat is important. I beleive Super Cubs can have a removable spreader bar holding up the back seat which is important to be in place during flight.
Capt. Kirk offline
1970 @#%&* M4 220C on Edo 2440
So, the FAA beleives that mechanics are more able to do the complicated W&B sheets than pilots are, and that pilots need to be shown the correct way to remove two 1/4" bolts holding the back seat in...after all, that "righty-tighty--lefty-loosey" thing can get pretty confusing sometimes :D.
Not all pilots are engineers Kirk. :wink:
Phil
Bear_Builder offline
So all these spread sheets on computers that will calculate your W&B for you aren't worth crap? Legally, I mean. Except of course to tell you what your CG and gross weight really is. I've gotten one from David Wright that legend has came from the NASA guy's. Apparently the have a Maule or two for something and one of them wrote a pretty darn good spread sheet for computing W&B. I fly with a Motion tablet as a class one EFB and I have a copy of this spreadsheet on it. I've worked it out by hand and it is real accurate, of course math is math right? Oh and the EFB has one as well, but I guess it isn't any good either.
a64pilot offline
a64,
I think you're confusing two seperate things here. Anything that you do to change the basic empty weight of a plane needs to be done by an A&P, lighter radios, floats, taking out the back seat, stuff thats designed to be permanent. The calculations you do for passengers and such don't require an A&P.
Dean offline
Aircraft: '54 C170B
'46 Fleet Canuck
Dean is correct. When equipment is added or removed, only a mechanic may re-calculate the W & B (at least technically speaking). The pilot is always able and expected to caculate a weight and balance for a particular loading before flight.
As to Kirk's comment about needing "permission" to remove or install a seat, if it requires only "simple procedures", you do not need any blessing to do so. A mechanic isn't authorized to "train" a pilot to install or remove a seat.
This notion probably comes from the FAR 135 world in Alaska, where each operator has to demonstrate a training procedure for their pilots to install and remove seats. The FAA got a little weird about this a few years ago, and said pilots couldn't remove or reinstall a seat, even a very simple one. Got egg on their face, and backed off to some degree.
If it's a complex deal, a mechanic would have to do it.
This is a really good argument for the Atlee Dodge or BAS folding seats, actually.
Dean,
I think you are exactly right, but I'm not sure that's it's me that is confused. As a mechanic, if I change the basic weight of an aircraft, then I have to recompute the aircrafts basic weight and moment.
But as a pilot, if I drop off a passenger, add some fuel and ice chests, I don't have to find an A&P to compute weight and balance. I believe as a pilot I'm required to ensure that the aircraft remains within CG and gross weight limits throught all phases of the flight. If I can't legally compute it, then how can I do that.
Now one way to do that is to compute several weight and balances, reference them and determine that you fall in the middle somewhere and therefore are within CG and gross weight limits.
BTW, I'm "typing" on my EFB tablet with a stylus, so it's worse than typing on a keyboard with one finger, please forgive the mistakes, slowness and short, choppy sentences.
[/code]
a64pilot offline
MTV,
It took so long for me to answer, I hadn't read your post. I see we ended up at the same place.
a64pilot offline
a64pilot wrote:Dean,
[/code]
A64
Think of it this way...
Consider the weight of an airplane as a "dead load"...and the stuff you put in it as a "live load"
A mechanic needs to weigh a plane and calculate its arm and fill out a W&B sheet and sign it for the "dead load" part of the plane. Seats are part of the dead load as they are intended to be a part of the plane. So, when you remove a seat, you don't need to re-weigh the plane but you need to have the mechanic subtract the weight of the seat from that particular station (arm) and then sign the "seat out" weight and balance.
So, when you as a pilot start loading fuel, passengers and gear into your plane you will use whatever "base" W&B fits your particular case. If you flew 4 people out, you'd use your "seat in" sheet, their weights and fuel...and you do that yourself...no mechanic or signature needed. When you removed the seat and stuffed the plane full of fish you'd use the "seat out" base W&B and go from there, again, no mechanic or signature needed.
Same thing for "floats, seat in" "floats, seat out"...etc. all which need a signature and need to be carried in the plane.
Capt. Kirk offline
A64...took me so long to type I didn't see you and MTV ended up at the same place :D
Capt. Kirk offline
I just re-read this thread and please let me try to clear up some things. You don't need sheets to cover wheels, floats and skis. you just need the one that covers the current aircraft configuration. I would keep the others on hand though so that when you have an A&P change the configuration you save him some work. Of course unless he is an idiot he has a copy on file.
I can't imagine why you would need seperate sheets for wheels or skis up and down. But, I have no experience with skis, so I could be wrong. I haven't seen one computed for the 210 that I fly, and if anything would need it, I would think it would be for an airplane that folds it's wheels like a duck. I think in order to get the STC approved for floats or skis you have to demonstrate no adverse effects in any configuration.
So unless I'm wrong if an A&P makes a repair or alteration to an aircraft that changes the basic weight or moment of an aircraft, then he has to recompute, but if it didn't take an A&P to change the aircraft, then it doesn't take one to compute.
I'm not so sure that an A&P is the lowest level that CAN make the computation as much as it is the an A&P is REQUIRED to compute a new W&B to complete his work.
I'm only talking part 91 here, 135, well let's just not go there.
a64pilot offline
Kirk,
My basic premise is that if YOU can remove or install it, then YOU can do the computation.
a64pilot offline
Great, we all agree. It's easy to miscommunicate this concept because a lot of the terminology is the same.
Required: Aircraft weight and balance sheet for empty weight. Can be generated from scales, amended calculations, whatever. It needs to be signed by A&P minimum and be kept on board. It's the W in "ARROW." Any configuration that adds or removes a "permanent" installation of the aircraft requires an additional W&B sheet of this type.
Like a64 says, only the current configuration's sheet needs to be onboard legally, but why not pack them all so they're all in one place?
Not required: A per flight weight and balance calculation that calculates the dynamic CG based on pilot, passengers, fuel, payload. Not required, but strongly recommended for every flight.
This horse just ain't quite dead yet. I think these are some of the major points. There maybe more.
1. You are required to ensure you operate within limits, a way to do that is to have multiple compution sheets, determine you fall somewhere between those extremes and you will stay within them throughout the flight, then your good. These sheets do not require a mechanic.
2. If you as a pilot can put it in or take it out, then you can do the computation.
3. If a mechanic does something to change the basic weight or moment, then he has to recompute or uncle sugar will visit him.
5. bottom line as always is that you are ultimately responsible.
6. Of course the sheet you carry has to match the current aircraft configuration.
I may have confused some AR's (ARMY regulations) with FAR's, I'm bad at that, but I don't think so.
a64pilot offline
a64pilot wrote:This horse just ain't quite dead yet. I think these are some of the major points. There maybe more.
I can take the rear seat in and out. So why do I need a different W&B signed by an A&P again?
Is the rear seat on most TCDS as required equipment?
iceman wrote:trust me you need a new weight and balance done by a a&p not necessarily an AI. Just calculating the W&B isn't enough. Good call Zane. My A&P advised me of this as did my old flight instructor. A&P just did one for me and I keep it in the plane. =D>
Depends on the plane. For the 182 I used to have you would be correct. I carried three W+B calculations on one sheet for that plane. All seats in, rear seat removed and rear and copilot seats removed. With my Bo only one W+B is required as the seats are basically cargo. The owners manual lists the weights and stations for each seat for calculating W+B. If you want to remove one seat you simply subtract the weight of the seat on the appropriate line of the given W+B form. So check to see how your aircraft handles it to be sure.
Bonanza Man offline
