It's kinda weird you know? It's a bit like running into an old girlfriend in a topless place. N2976L a 1967 Mooney M20C brown on cream. It's had a new engine put in for some reason. It had 1250 SMOH when I sold her in 93 or so and the spec sheet says factory new engine in '94. I sold it to a trust fund baby and I remember him calling me because it used a quart every 7 and he though that I had lied to him. This was the engine that had the wrong valve springs put in one cylinder at an overhaul before I got it. An old round engine guy figured out why cylinder #3 kept needing rebuilt every 80 hours or so.
Anyway she's had good care it looks like. New panel. Nice stack compared to the crap I had in it. Still has the Brittain wing leveler. I know she was in Weed California for many years in a partnership then went to Florida about 5 years ago. I think all of that stuff and the new interior and panel would probably have come to way more than the $17000 difference in what I sold her for and what they are asking. I put in the one piece windshield and the stainless brakes, turned the brakes around so they are inside the wells and removed the shimmy dampner. I put a lot of work into making the plenum tight and leakproof with new rubber and mounts. I hope somebody changed the scat hose. It used to smoke when you turned the heat on. Hehhehhehheh. I got skeert real bad one time when I turned the heat on going over the cascades and SMOKE started coming out the defrost vents. A-and I ain't askeert of nothin'!! I fixed up the nose gear door so that it actually closed and made the main doors close flush.That's a fast airplane there. I had the clock in the yoke rebuilt by a clockmaker. It kept perfect time. Anyway, makes me lonesome. I showed the ad to the missus and she got kinda wistful too. Lot's of memories in that old bird.
(I'd post the link but I think it's not Kosher because it's not mine. You have enough info to track her down on Barnstormers if you want to.)
