Backcountry Pilot • N numbers experimental
9 postsPage 1 of 1
What's the rules for number ht and location on experimental?
Thanks gary
shortfielder offline
Re: N numbers experimental
Without quoting from FAA I just remember they need to be at least three inches as a tail number. But if you want to fly to the Bahamas then 10. (Correction: may be 12)
Addition
Effective November 13th, 2007, N-numbers:
Must be at least 3 inches high
Can now be applied to non-structural surfaces
And can be affixed in a horizontal or vertical (stacked) orientation.
dirtstrip offline
Smaller the better for me. Wanna keep the wt. down. :wink: Never thought about stackin them.
Thanks gary
Gary,
Did you get something?
Arnie
Magnet offline
Magnet
shortfielder wrote:What's the rules for number ht and location on experimental?
Thanks gary
12" if ya want to leave the country. 3" will work on most homebuilts unless they exceed a certain speed, then its 12".... I am sure it's in the FAR's somewhere but I get dizzy reading that legal crap.
Stol offline
3" yes, and you can locate them on your vertical fin so they are easily visible and you are fully compliant when you are on the ground, once aloft they will be pretty much blanked out by the hor stab making them pretty tough to read, just saying. Not sure why anyone would do that :twisted:
You can of course put them on the bottom surface of the wing, 12" or larger, just to ensure you are readily identifiable at all times, the choice is yours, man I love America!
Hey Arnie.
Na, nuthin yet. Still lookin pretty hard. Had a couple I liked go away.
Gary
What ever happened to that C182? Did you sell it, part it out, or ?
Here's the answer??
45.29 Size of marks.
top
(a) Except as provided in paragraph (f) of this section, each operator of an aircraft must display marks on the aircraft meeting the size requirements of this section.
(b) Height. Except as provided in paragraph (h) of this part, the nationality and registration marks must be of equal height and on—
(1) Fixed-wing aircraft, must be at least 12 inches high, except that:
(i) An aircraft displaying marks at least 2 inches high before November 1, 1981 and an aircraft manufactured after November 2, 1981, but before January 1, 1983, may display those marks until the aircraft is repainted or the marks are repainted, restored, or changed;
(ii) Marks at least 3 inches high may be displayed on a glider;
(iii) Marks at least 3 inches high may be displayed on an aircraft for which the FAA has issued an experimental certificate under §21.191 (d), §21.191 (g), or §21.191 (i) of this chapter to operate as an exhibition aircraft, an amateur-built aircraft, or a light-sport aircraft when the maximum cruising speed of the aircraft does not exceed 180 knots CAS; and
(iv) Marks may be displayed on an exhibition, antique, or other aircraft in accordance with §45.22.
(2) Airships, spherical balloons, nonspherical balloons, powered parachutes, and weight-shift-control aircraft must be at least 3 inches high; and
(3) Rotorcraft, must be at least 12 inches high, except that rotorcraft displaying before April 18, 1983, marks required by §45.29(b)(3) in effect on April 17, 1983, and rotorcraft manufactured on or after April 18, 1983, but before December 31, 1983, may display those marks until the aircraft is repainted or the marks are repainted, restored, or changed.
(c) Width. Characters must be two-thirds as wide as they are high, except the number “1”, which must be one-sixth as wide as it is high, and the letters “M” and “W” which may be as wide as they are high.
(d) Thickness. Characters must be formed by solid lines one-sixth as thick as the character is high.
(e) Spacing. The space between each character may not be less than one-fourth of the character width.
(f) If either one of the surfaces authorized for displaying required marks under §45.25 is large enough for display of marks meeting the size requirements of this section and the other is not, full size marks must be placed on the larger surface. If neither surface is large enough for full-size marks, marks as large as practicable must be displayed on the larger of the two surfaces. If no surface authorized to be marked by §45.27 is large enough for full-size marks, marks as large as practicable must be placed on the largest of the authorized surfaces. However, powered parachutes and weight-shift-control aircraft must display marks at least 3 inches high.
(g) Uniformity. The marks required by this part for fixed-wing aircraft must have the same height, width, thickness, and spacing on both sides of the aircraft.
(h) After March 7, 1988, each operator of an aircraft penetrating an ADIZ or DEWIZ must display on that aircraft temporary or permanent nationality and registration marks at least 12 inches high.
ALSO
(b) A small U.S.-registered aircraft built at least 30 years ago or a U.S.-registered aircraft for which an experimental certificate has been issued under §21.191(d) or 21.191(g) for operation as an exhibition aircraft or as an amateur-built aircraft and which has the same external configuration as an aircraft built at least 30 years ago may be operated without displaying marks in accordance with §§45.21 and 45.23 through 45.33 if:
(1) It displays in accordance with §45.21(c) marks at least 2 inches high on each side of the fuselage or vertical tail surface consisting of the Roman capital letter “N” followed by:
(i) The U.S. registration number of the aircraft; or
(ii) The symbol appropriate to the airworthiness certificate of the aircraft (“C”, standard; “R”, restricted; “L”, limited; or “X”, experimental) followed by the U.S. registration number of the aircraft; and
(2) It displays no other mark that begins with the letter “N” anywhere on the aircraft, unless it is the same mark that is displayed under paragraph (b)(1) of this section.
(c) No person may operate an aircraft under paragraph (a) or (b) of this section—
(1) In an ADIZ or DEWIZ described in Part 99 of this chapter unless it temporarily bears marks in accordance with §§45.21 and 45.23 through 45.33;
(2) In a foreign country unless that country consents to that operation; or
(3) In any operation conducted under Part 121, 133, 135, or 137 of this chapter.
(d) If, due to the configuration of an aircraft, it is impossible for a person to mark it in accordance with §§45.21 and 45.23 through 45.33, he may apply to the FAA for a different marking procedure.
Whew!
GT
M6RV6 offline
9 postsPage 1 of 1
