Mister701 wrote:..... Take a ball peen hammer, the larger the better. Place the Narco on a firm concrete or steel surface; the harder the better. Whack it good now. ...
Mine burned up the final amplifier transistors every single flight but after repair, soup to nuts inspection and testing of the antenna and transmission line the radio worked great on the ramp. It worked a few trips around the patch with the avionics shop monitoring transmissions. Etc. Then after an hour, maybe two, it burned up the finals again. The shop wouldn't warrantee the work after the second set. I really do think that in the end it had to be something about the install but they couldn't find it and neither could I. I had the AT50 also and it worked peachy.hotrod180 wrote:Mister701 wrote:..... Take a ball peen hammer, the larger the better. Place the Narco on a firm concrete or steel surface; the harder the better. Whack it good now. ...
I had a Narco AT50 or 50A txp in my 170, people badmouth those but mine worked great for the 11 or 12 years I owned the airplane. It had a King KX155 which I liked. I installed an Icom A200 in my C150TD and liked it too.
Along with the 810 com, my 180 has a matching Narco AT150 txp, both installed back in 1992. Both are still looking relatively new, and except for the radio being a bit scratchy (probably due more to the installation than the radio), both work just fine. I don't particularly care for having to reset the com freq's every time, but as long as it keeps working I'll keep it. If & when it needs replacing, I'll probably go with an Icom A210, but for now I think I have better uses for the $1300 or so that they cost.
