Need help with airstrip construction
Fri Jun 23, 2006 10:25 pm
delete
buzzlatka on Mon Dec 28, 2009 9:45 am, edited 2 times in total.
buzzlatka offline
161
For whatever it is worth, Illinois requires at total of 140 feet clear of obstacles from side to side. I am on the prairie and built my grass strip 70 feet wide and admit to having been cose to both sides of it at one time or another in tough crosswinds. I would guess that with your tree situation it might be more challenging at times. This thought coming from a flatlander that thinks a 1000 foot strip is short.
steve offline
822
- Aircraft: 1980 Cessna 185F
I am building one in nor cal. I know that some folks think that nor cal is anything north of Bakersfield. We are 40 miles south of the Oregon border.
In siskiyou county they require that you have at least 200 acres and get a use permit for the airport. I have 120 acres and screw the pemit. I will not be ofering services at my landing strip so I do not feel that it is an airport.
100 ft clear of centerline is plenty and your length sounds great.
BUILD IT AND WE WILL COME
3633
- FindMeSpot URL: http://share.findmespot.com/shared/face ... I5tqEOk0rc
- Aircraft: Cessna 182
delete
buzzlatka on Mon Dec 28, 2009 9:45 am, edited 1 time in total.
buzzlatka offline
161
Sounds like you already have it figured out. I wouldn't try to comply with "airport" regulations. I have no idea how you might limit liability of other people using your strip though. I regularly fly into and out of crop duster strips that are much smaller than you describe. Down south here if you can fit it in and have the property owners permission, then you have a strip. At least for dry fertilizer anyway. I'm sure there are regulations, but we try the three mouse rule. See, hear and speak no evil. Just make sure if your insured, it allows you to land there.
a64pilot offline
1398
Make sure you put X's at the end of the runways and make sure everyone knows that they 'don't' have permission to land there - that should help to shield you from some of your liability concerns.
Strata Rocketeer offline
504
"I've been ionized, but I'm okay now." - Buckaroo Bonzai
On my private strip, 2WY3, here in Wyoming I hardly ever have a uninvited person drop in, The X thing is a good idea altho I don't know how much it will limit liability. At least in court I can say" I told ya so" Lawsuits are few and far between in Wyo, here we just take the whinners and feed them to the bears, the darn things hate the taste of lawyers though.. <G>
Stol offline
1048
I used 600ft of my hayfield as a strip in Oregon's Willamette valley and was advised by OR Aeronautics to not mark an X or R or windsock so therefore it was not an identifyable strip and thus salvage rights are yours if someone comes in and messes up.
There are a number of potential landing sites on some of those Delta islands in the dry beds among the bushes, in fact theres a barge out there that is awfully tempting. Many of the landing sites around are narrower than 100ft though that would be nice. The wheel track available at Calistoga airstrip before it was closed was 14ft wide and nobody went off the side. You could blade up a raised 20ft strip and get earlier spring use and later winter use.
You won't need a sock as the water all around suffices.
Jeremy
maules.com offline
561
Mon Jun 26, 2006 10:33 am
Barge? Carrier landings anyone? Sounds ballsy. How long is a barge anyway?
a64pilot offline
1398
deltet
buzzlatka on Mon Dec 28, 2009 9:46 am, edited 1 time in total.
buzzlatka offline
161
Barges can be 40 to 400ft, I can't find it on earthmap so will look next time over the Delta. I did find your proposed strip, looks good though a west crosswind will be significant at the wrong time of day.
Jeremy
maules.com offline
561
d
buzzlatka on Mon Dec 28, 2009 9:47 am, edited 1 time in total.
buzzlatka offline
161
d
buzzlatka offline
161
d
buzzlatka on Mon Dec 28, 2009 9:48 am, edited 1 time in total.
buzzlatka offline
161
buzzlatka wrote:Problem is that this runway my be at the limits of my 170.
At the end of the strip, build a jump.
2855
From the looks of the photo, there is farming on the other side of the channel. They probably do there plowing and discing in the late summer when the ground is the dryest.
Maybe get one of the farmers to disk up the place, pull a land plane then plant grass.
3633
zane wrote:buzzlatka wrote:Problem is that this runway my be at the limits of my 170.
My very first ever airplane ride was in a 170B off a strip with a jump at the end... I'll never forget that one!!!
JH
hardtailjohn offline
924
I am in the process of getting an approved strip, but I am within a Class D airspace. It is getting to be quite a hastle. Fill out form FAA form 7480 and they should approve your strip and put it on the map. This should be quite easy to do if you are not in any other airspace. At one time after 9-11 the FAA made every plane fly in our out of an approved airstrip. They have relaxed this rule now.
Mine was declined until I get a Letter of Agreement from the local Class D airport. They are dragging their feet because they dont want to do it, but I dont think they have a choice. This has been going on since Feb. They then have to submit the LOA to the upper folks at FAA for approval. Then I should get an approved airstrip. If it is declined, I just go on up the ladder to someone else. Everybody tells me they cant tell you that you cant land on your own private land. Then since I am in the city limits, I have to get a permit from them, but my buddy is the Mayor so that wont be a problem.
On the form 7480 you can choose the strip to be private or public. Mine will be private for me and guests. The guests are required to read the LOA before using the strip. All the LOA does it tells radio frequencys and patterns and directions to fly in and out so not to get in the other airports way. I am near Tulsa.
SteveE offline
3
