Backcountry Pilot • Need Oil Pressure Sending Unit 0-470
6 postsPage 1 of 1
Hi Guys-
I need an oil pressure sending unit for my 0-470. Any ideas or options? Cessna only sells the sending unit and gauge as a kit.
Thanks in advance for your ideas......
DBI offline
Re: Need Oil Pressure Sending Unit 0-470
There are a bunch of options on aircraft spruce. http://www.aircraftspruce.com/catalog/inpages/mitchell9039.php?clickkey=13212
Just pick your gauge range and make sure its the right ohm range.
PAMR MX offline
One of these?? (On the left). Removed in working condition, I replaced my cluster with electronic gauges.
If your AOG I'll send it to ya, no charge just pay it forward. PM me your name and shipping address if you want it.
bart offline
Aircraft: Cessna 180
Bart- I just sent you a PM. Yes, I want it, thank you!!!!!!
DBI offline
[quote="DBI"]Hi Guys-
Thanks in advance for your ideas......[/quot
Oil Pressure or Temperature ? Oil pressure line is on bottom of 0-470-Lor R between Cylinders 2 & 4 .Oil Temperature pickup is below oil cooler . What I see in picture is for oil Temperature . Oil Pressure line is 1/8th copper line available at auto zone by the foot ,just flare the ends to match .
182 STOL driver offline
It's on the way, should be arriving Friday afternoon. I'll PM you soon with tracking info.
bart offline
6 postsPage 1 of 1
