Backcountry Pilot • Need some help with redline CHT's with a Franklin 220!
6 posts • Page 1 of 1
Do any of you know what the maximum CHT is for the 6A-350-C1R Franklin 220? All I can find is 392 Degrees in a couple of references. Does that sound right?
Ordering a new monitor and I can't find it anywhere.
Thanks in advance!
Jim
jaudette offline
Aircraft: Husky A-1B
Vans RV-7a
Re: Need some help with redline CHT's with a Franklin 220!
TangoFox offline
Keep the Greasy side down!
It might be worth noting that the max CHT temp specified is based on using a bayonet thermocouple type sensor.
FWIW the Continental O-470 TCDS calls out two different CHT limits for bayonet probe vs a sparkplug gasket type probe.
For the 470K it's 460 degrees vs 525 degrees-- quite a difference!
The 220 Franklin in the Maule has a service bulletin to place a sleeve around the CHT probe which is to contact the bottom of the hole in the top of the cylinder. This was to get a more accurate reading. Operators handbook says 390 F but does not stipulate the word "maximum"
maules.com offline
I think 390 is the number. I'm using a bayonet type probe.
Thanks for the help guys!
Jim
jaudette offline
Vans RV-7a
The Franklin 165 is the same way.
530F for Sparkplug type
445F Bayonet type
310F Cylinder barrel
IMO you should grab a copy of the Franklin 220 Operating manual. As hotrod180 pointed out, the spread is large, making assumptions isn't worth it.
TheMachinist1 offline
Aircraft: Stinson 108-3
