Check out the website:
http://www.surefly.aero/home.html
Good things are coming!
MontanaT-craft wrote:I discovered that it won't work for me since it requires continuous power for all operations, and I do not have an electric system. I think that also means that if your battery fails, your engine quits. I would not look forward to that possibility.
hotrod180 wrote:Exactly how is an electronic ignition system better than a magneto?
I know mags are ancient technology, but so is a hammer and they still work pretty well.
Zzz wrote:hotrod180 wrote:Exactly how is an electronic ignition system better than a magneto?
Their entire website homepage seems dedicated to listing reasons why.
DeltaRomeo wrote:SureFly ignition systems, developed by the same staff that developed Plane Power Alternators and Sky-Tec starters, has introduced to the EAB market (and soon to the rest of us, pending FAA approval) a plug and play electronic ignition product to replace our outdated mags. No points, no condenser, no cap and rotor, higher voltage and dwell angle spark, and load variable timing curve will provide a more powerful spark and provide better efficiency and lower maintenance point failures than mags. And at $1250 for 4 cylinder engines, it is a VERY affordable alternative! Really looking forward to having one of these on the M5!
Good things are coming!![]()
JP256 wrote:For my EAB Bearhawk Patrol, I'm leaning towards the P-Mag (from E-Mag.com - yeah, I know it's confusing). This one is self-powered, so no worries about electrical failure leaving you stranded. I went to one of their forums at OSH, and was impressed by the system.
hotrod180 wrote:Not to be a wet blanket, but again-- what's the advantage over a standard magneto?
