Spindrift wrote:Hi All,
Here's the planned route for the interested:
Redmond, Oregon to Rangely, Colorado (where Dad will pick her up to do some driving and talking/visiting)
KRDM - ILR - BOI - KBYI - MLD - KFBR - 33U - 4V0
Thanks,
Spindrift
Sounds like a great trip! I would recommend a couple of minor changes: Use S66 (Homedale) instead of BOI, this will still keep you out of Saddle MOA and R-3203, but also out of Boise airspace and shorten the dogleg a little. Down by Logan, if you use MLD-LHO-FBR, you will be over the canyon leading east from Logan instead of over the highest part of the range. You could do the whole trip at 9500, although with any tailwind 11,500 might be worth it. Another route would be to follow I-84 southeast from Burley until 20 miles West of Logan, then turn to FBR...this would accomplish the same thing.
These ranges have many lower passes through them, and the valleys are all ranching country with many possible emergency sites, so I don't consider it all that intimidating a route. The most remote sections are Logan to FBR and Dutch John to Rangely. You might want to continue Southeast from Dutch John twenty miles or so through Brown's Park before turning South to Rangely to avoid the rough terrain North of Dinosaur NP, although following the Green river through the Gates of Lodore is some of the most spectacular flightseeing you could find!
You have a well equipped plane so weather is the only factor that might force a change in routing. You are probably aware that on a moderately unstable Spring day, the mountains are the first place showers start, and that might make I-84 a better choice, as well as giving the Uintah range a wider berth. In fact, that range is such a weather producer that having BYI-BMC-42U-36U-MTU-4V0 as an alternate route to go Southwest of them is a good idea, as typically the storms will form over them and then drift Northeast to East, obscuring the lower terrain around Dutch John intermittedly in rain showers, particularly after noon to 2pm.
Of course, the Wasatch range can do the same thing, but I've been able to thread my way around showers in the Heber City to Morgan City area with success when the mountains were obscured. It's only 42nm between them, so turning around, landing and waiting for a shower to pass is pretty easy. If you continue Southeast from Heber about 15 miles, folowing the road, you will be over the lowest terrain. Don't forget to look in the rearview mirror!
I always play around with something like AOPA's online flight planner or the free Golden Eagle Duats software before a longer flight like this, rubberbanding the route until I'm pretty familiar with most of the identifiers, so that a major inflight change of plans is just a few keystrokes away, no stress. I have dozens of flight routes kept on my computer in the Mapsource TopoUSA software so all I have to do is dump the appropriate ones into the GPS before a flight. If you don't have that software, you should still build the route and alternate on the 396 before flight. Then all you have to do is follow the Yellow Brick Road and enjoy the scenery!
Google Earth is also a fantastic way to familiarize yourself with the terrain on the whole route.
Have a great trip!
Rocky
