FloatFlyer wrote:Hi Gump. I just heard from a friend that just got back from Bella Bella salmon fishing. He has a friend that runs the harbor in Namu and might be able to set me up with a fishing opportunity!! I will persue this. You want to run up here??
Backcountry Tundra wrote:Ford, this better be a lie cause the whole Yukon & Ak will be shut down!
qmdv wrote:Is there a field aproval or stc to put an O470 in a 185. Guess that is not that funny. This is just the beginning.
180Marty wrote:Steve, according to the Pponk website they take a TSIO520(low compression), put a carb on and get 275 or 285 hp. Not sure if the 275 is low comp. and the 285 high( maybe Gary can explain). According to to the Texas Skyways site they get 280 out of an O-520 and 285 out of an O 550. Those might be high compression. Would imagine if you made the 550 low compression it would still be pretty good. Also, if the 550 was still injected and compression lowered, should still be pretty good.
