Battson wrote:Are you seeing much gravel rash on the leading edge of the tailwings?
With the combination of higher touchdown speeds throwing more rocks higher up, very low horizontal stabiliser ground clearance at touchdown, and higher tire pressure disturbing more rocks (compared to say, Carbon Cub, in all three criteria) - I am interested to hear how you're finding it wears on the plane/
Nice to maintain a good cruise speed if you can get away without three large tires.
motoadve wrote:Horizontal Its all beat up, and looks horrible.
slowmover wrote:Seems like a thin layer of rubber or polyurethane applied to the underside might be worth it to some operators.
slowmover wrote:Great video... thanks for sharing. How much do you think your use of AoA improves your landing performance?motoadve wrote:Horizontal Its all beat up, and looks horrible.
I've seen the leading edge protection devices available... boots, tape, etc. I'm somewhat surprised that nobody has developed a solution for the underside of the horizontal stab. Seems like a thin layer of rubber or polyurethane applied to the underside might be worth it to some operators.
contactflying wrote:Check with your IA. They are pretty fussy about putting stuff on control surfaces. You want them to work as designed. That horizontal stabilizer is an upside down wing, you know.
JP256 wrote:slowmover wrote:Seems like a thin layer of rubber or polyurethane applied to the underside might be worth it to some operators.
That bedliner stuff would be great protection, but adding that much weight that far back on the plane probably is not a great idea...
motoadve wrote:I kind of learned to fly with the AoA, since I had no backcountry instructor, after I got my PPL and I was going to learn on my own, was one of the first things I bought. Its more accurate than an airspeed indicator, gives you more information than a stall warning, its over the glare shield in your peripheral vision, allows you to squeeze as much performance as possible from the plane, I really like it, I bought one for my CJ6 Nanchang, as soon as I bought the plane.
