I am a strong proponent of the greater safety of the energy management turn in any contact, or non-IFR, flight regime. Low level, or contour, flying at a certain altitude can be done somewhat safely using level turns. This is because, even at fifty feet, some vertical space is available for gravity thrust in the turn should the airplane start shaking near an accelerated stall. Also, we are not likely to put a wing down into terrain or obstacles. Also, we can level the wing and turn wide in the greater than NOE horizontal space. Still, this is hard on the back and on the aircraft and some of us just don't like a lot of load factor in our turns.
NOE, or nape of the earth, is different. We are as close to terrain as possible. We are in low ground effect. We have no vertical space and limited horizontal space to work with. We cannot safely make a level turn. We would put the down wing into a wire or terrain. Our safest option is to stay ahead of the airplane, anticipate the turn in the river or pipeline, zoom up to create vertical space for the down wing and slow down to decrease the radius of the turn, turn steeply using lots of rudder to get the nose pointed quickly at the new target (river or line going in the new direction,) allow the nose to go down onto the target naturally (don't pull back on the stick in the turn,) and level the wing before re-entering ground effect (NOE.)
What if we are behind the aircraft or the turn in the river or pipeline is gentle? We can use the wings level rudder turn in ground effect.
What if we are a strong opponent of the energy management turn and of the wings level rudder turn or we just don't want to learn or use them? What are our options when encountering a tight turn in the river or pipeline? We can zoom up using cruise speed kinetic energy to hopefully out climb wires, trees, and terrain. If we go ahead and attempt the turn, we will have to do a modified energy management turn to make some vertical space for the down wing. However, to stay in the right of way or between the trees and terrain in the river (we are still at cruise speed,) we will have to turn without much vertical space to create gravity thrust in the turn. Load factor will become so prevalent that we may have to level the wing to prevent mush into the river. Now we are facing the last life saving solution: Controlled Flight Into Terrain.
Even with the excellent photography in the videos, it is hard to tell the difference between NOE and Low Level. Except for the wake evidence from the big tires in the river.
