Backcountry Pilot • Normal/Utility Category
11 postsPage 1 of 1
One of the reasons I purchased a Cessna 180 was due to its reputation as being a robust aircraft capable of hauling pretty much anything you were capable of pushing through the door, and getting in and out of unimproved airstrips. What I can't seem to wrap my head around is the fact that it is certified in the Normal category. In my mind, Utility equates with "robust" and Normal seems more of a "gentleman's" use category.
Anyone have any thoughts on this with respect to the C180's reputation? Was Normal category defined differently when these aircraft were built?
NMXWinds offline
Aircraft: Cessna 180J Skywagon
Re: Normal/Utility Category
It would be utility if it weighed 13,000 pounds and had up to nine seats.
Nosedragger offline
Then how do you explain how a C172 is Utility category (in some loading configurations) or that a Grumman Tiger is Utility?
NMXWinds offline
Hmm, I don't know about a 172 but the Tiger is light aerobatic isn't it? Limited Aerobatic gets a utility rating too.
Nosedragger offline
Normal and Utility Categories refer to the Certification Category of the aircraft, based (largely) on the demonstrated flying characteristic of the aircraft. The terms do not refer to an aircraft's intended purpose of mission.
For example: The 172 is certified in both the Utility and Normal Categories. It is restricted to the Utility Category if spins are being conducted. This restriction in the 172 is a function of gross weight and CofG. In other aircraft the category may be a function things such as trim position, strakes, weight, balance or a combination of any of these factors.
In the Utility Category, one of the characteristics the aircraft (the 172 in this example) must demonstrate is the ability to recover from a spin without control inputs after no more than three rotations in the spin. This is one of many of the characteristics that must be demonstrated in order to obtain a Utility Category Certification. In the Normal Category, spin recovery can rely on pilot input in order to recover from a spin but the aircraft must recover from the spin after a set number of rotations (I think it's no more than 1.5 rotation but my memory could be off on that).
There are many aircraft that do not have Utility Category Certification. They are certified in the Normal Category. These are often (but not always) easily identified by a placard that states something to the effect that "Aerobatics, Including Spins, are Prohibited".
Hope this helps.
northernguy offline
I have an airplane certified in both normal and utility (pa 12). GW in normal is 1750, in utility it is less (cant recall). I believe it has to do with the load factor the aircraft can sustain before failure.
scruiser offline
Northernguy, thanks for the explanation. I was always under the impression that the categories were based entirely on airframe strength, which is why I couldn't reconcile the 180's reputation with it's Normal category. What you say makes sense.
NMXWinds offline
northernguy wrote:Normal and Utility Categories refer to the Certification Category of the aircraft, based (largely) on the demonstrated flying characteristic of the aircraft. The terms do not refer to an aircraft's intended purpose of mission.
Hope this helps.
Not quite. Actually, the difference is in permissable load factor. Here's a "sort of" description of the differences:
Category
Normal Category is a certification category. This category has a maximum G loading of +3.8 G's (positive G's) -1.52 G's (negative G's). Usually spins and other maneuvers that exceed the normal flight envelope are prohibited.
Utility Category is a certification category. This category has a maximum G loading of +4.4 G's and -1.76 G's. Aircraft in this category are approved for maneuvers that are not acceptable in the Normal category. Spins are required for certification in the Utility category, IF the aircraft model is approved for spins.
From Part 23:
§23.3 Airplane categories.
(a) The normal category is limited to airplanes that have a seating configuration, excluding pilot seats, of nine or less, a maximum certificated takeoff weight of 12,500 pounds or less, and intended for nonacrobatic operation. Nonacrobatic operation includes:
(1) Any maneuver incident to normal flying;
(2) Stalls (except whip stalls); and
(3) Lazy eights, chandelles, and steep turns, in which the angle of bank is not more than 60 degrees.
(b) The utility category is limited to airplanes that have a seating configuration, excluding pilot seats, of nine or less, a maximum certificated takeoff weight of 12,500 pounds or less, and intended for limited acrobatic operation. Airplanes certificated in the utility category may be used in any of the operations covered under paragraph (a) of this section and in limited acrobatic operations. Limited acrobatic operation includes:
(1) Spins (if approved for the particular type of airplane); and
(2) Lazy eights, chandelles, and steep turns, or similar maneuvers, in which the angle of bank is more than 60 degrees but not more than 90 degrees.
So, a Utility category airplane is certificated to higher load factors on the airframe. Many Utility category airplanes are certified for spins, but not all are.
A utility category airplane is, by definition, somewhat stronger than a Normal category airplane, but the differences aren't huge.
An example of a manufacturer using this as a sales pitch was Aero Commander and Bob Hoover demonstrating the airplane's strength, since it was certificated in the Utility category. Interestingly, Hoover flew the airplane so smoothly in his demonstrations that he never even came close to exceeding the Normal category certification limits.....
Utility category airplanes are only stronger at the same gross weight, note gross weight not maximum gross weight. On the 170 and 172 Cessna reduces the maximum gross weight to a lower number when operated in the utility category. They also restrict the cg for spin recovery. So if you were comparing a normal and a utility category airplane both certificated to the same maximum gross weight the utility category airplane would be "stronger" but only in this type of comparison. To make it easy, if you want the "robustness" of a utility category airplane just multiply your normal category max gross weight by 3.8 divide by 4.4 and use that as your new maximum gross weight. Spins still not approved.
bat443 offline
bat443 wrote:Utility category airplanes are only stronger at the same gross weight, note gross weight not maximum gross weight. On the 170 and 172 Cessna reduces the maximum gross weight to a lower number when operated in the utility category. They also restrict the cg for spin recovery. So if you were comparing a normal and a utility category airplane both certificated to the same maximum gross weight the utility category airplane would be "stronger" but only in this type of comparison. To make it easy, if you want the "robustness" of a utility category airplane just multiply your normal category max gross weight by 3.8 divide by 4.4 and use that as your new maximum gross weight. Spins still not approved.
Tim,
That is generally true, but not always. There are a few aircraft that are certified to Utility standards at max weight. Not many, and as you note, this is something that is often overlooked.
A prime example is the Super Cub. The PA 18 Super Cub is certified to 1750 lbs All Up Weight in the Normal category (at least the later, 150 hp versions). But, the airplane is certified to only 1500 pounds All Up Weight in the Utility category.
But, with some regularity, one sees folks posting on the internet that they and their buddy were out doing spins in a Super Cub, the empty weight of which is 1250 or so......
Good points.
Yep, the Bonanza is utility category all the way to max gross.
Bonanza Man offline
11 postsPage 1 of 1
